I just picked up a 2003 Base LS430 for my son. I've been having lots of fun driving it to "shake it down" and have been busy searching and reading the forums tweaking and addressing a few minor issues: power mirror switch, center console difficult to open, a bulb or two, trunk lifts, added a VAIS MML and USB port, and lastly, fixed the driver's seat recline by replacing the recline motor. When I'm done, I may just have to keep this LS for myself!
Anyway, my question is regarding the driver's memory seat function. The memory seems to be working normally, with the exception that the seat angle/recline position is not memorized. Is this normal? I'm guessing not, since my other Lexus cars all remember the recline position.
I have tried several different suggestions found on the forum to reset the seat memory with no luck (basically, remove/replace battery cable, and exercise the seat in a couple of different sequences), but the recline position is not being memorized. Everything else is properly memorized: seat vertical/horizontal, thigh extension, headrest, shoulder belt, and steering wheel. (Edit: also outside mirrors)
Thank so much for the advice, RKW! I was able to fix the no-recline-memory issue by replacing the gear/sensor assembly!
I had bought a used motor/gear/sensor assembly and installed it to fix the original no-recline issue, so I just swapped out the gear/sensor portion from the original dead motor, and now the memory-recline works.
I'm a bit nervous that this old assembly could damage my replacement motor, but it does seem to be working fine at the moment. The old motor is totally unresponsive (no sound/no movement), but also appears to have a broken drive shaft, which I suppose could have been caused by this gear assembly binding. Time will tell. The failure of these motors doesn't sound very common, based on my forum searches, so I wish I know why/how it failed.
Here is a picture of the defective gear/sensor assembly that came with the used replacement motor assembly, for those who have never seen this part. Replacing this motor was a pretty easy fix and I was able to do it without removing the driver's seat.
