Compass won't calibrate
Old Aug 27, 2017 | 05:58 AM
tradosauru's Avatar
tradosauru
Default Compass won't calibrate
I followed the directions on the manual at least three times but to no avail. Any other solutions?
Old Aug 27, 2017 | 07:09 AM
2KHarrier's Avatar
2KHarrier
That's the only way I know how to calibrate it. I've had to calibrate mine a couple times, and I'm able to get it corrected after driving in a circle, or around the block. No indie needed...
Old Aug 27, 2017 | 09:59 AM
rkw77080's Avatar
rkw77080
Here are pages from the repair manual. Hopefully they are helpful...
Old Aug 28, 2017 | 02:51 PM
PearlUni05's Avatar
PearlUni05
Not trying to get way off topic here, but when I select "DISP2" on my steering I only get temperature. Either on or off and nothing else. Are you saying it is supposed to show you compass(direction) too/either or/both?
Old Aug 28, 2017 | 04:48 PM
rkw77080's Avatar
rkw77080
This option is not available if your car is equipped with a navigation system...
Old Aug 28, 2017 | 05:03 PM
PearlUni05's Avatar
PearlUni05
Ahhhh ok. Thanks for clarifying. I'm still learning this car.
Old Aug 27, 2019 | 04:36 PM
Pughnitive's Avatar
Pughnitive
Hello, good people of CL! It's been a couple of years since anyone has commented on this thread but I couldn't find more info anywhere else.
I have a 2001 LS430. I followed the instructions several times and the compass is still incorrect. The manual says to demag the car in case the compass has been magnetized. I have a demag'er that I use for analog tape machine heads. Do I need to demag the entire car or just where the compass is located? If just the compass, where is it?
In addition, I recently acquired Techstream software to monitor the car's computer and customize some settings. In there is a compass calibration page. I'm able to select a bunch of different numbers but not N, S, E, W...I didn't know what was going on so I stopped. Does anyone know how to use that? I'll grab screenshots next time I use Techstream.
Thanks!
Old Aug 27, 2019 | 05:54 PM
rkw77080's Avatar
rkw77080
Please give these instructions (from Owner's Manual) a try...
Old Sep 3, 2019 | 06:14 AM
Pughnitive's Avatar
Pughnitive
@rkw77080 Thank you. I followed the instructions. Seems to be stable now after driving 30-40 miles.
lesz
14
Feb 5, 2017 02:12 PM
Squirrelsb
HS 250h Model (2010-2012)
Mar 13, 2010 02:37 PM
shikbas
RX - 1st Gen (1999-2003)
Nov 2, 2008 05:58 AM
