Electrical gremlin LS430
From looking at the parts list, it says intake manifold gaskets, so I am assuming they had to remove the intake manifolds to get to the starter. I bought this car new, and usually keep my cars 10 years, but this has been such a good car, with very low out of pocket expenses, that I thought I would keep this one until 200K miles, or roughly 20 years. So in this last year, I had Lexus replace the timing belt, water pump, anti-freeze and I told them all the moving pulley's while in there. Hopefully they did.
I had new brakes put on, spark plugs installed, and the fluid in the tranny and differentlal changed, all of which I consider to be normal maintenance. The starter is the first failure of a part.
We are the original owners, basically my wife's car, and she treats it well. Just had new brakes put on around 103K and only did it because I could not believe OEM brakes could last that long, and I didn't want to hear that squeal when the metal touches metal. Come to find out, the LS430 has an electronic warning.
Yes---the brakes have an electronic 'wear indicator' on the passenger front and passenger rear side only. If/when it gets to that point and shows up on the dashboard the brakes need replacing, the electronic sensor has to be replaced too. Tack on another ~$25, lol.
The invoice does not indicate how many hours charged. However when I took it in, they said they would check it out and let me know what they found. Around 11AM they called to say it was the starter, and it was a labor intensive job, that it was in the valley, whatever that is, and they had to remove things. They said it would take their tech all day to replace the starter, so to take their loaner car home, which we did.
Good luck and roll on 4EVER!!
Picked it up Saturday, cost was $1388. Listed below are the parts they used, plus labor, and since I scheduled the service on line, they had a 10% discount.
Total charge was $1388. Most of it labor,
PARTS------QTY---FP-NUMBER---------------DESCRIPTION--------------------UNIT PRICE----JOB
# 1********** 1*****28100-50110-84******* REMAN STARTER *** ********334.74 *******334.74
JOB # 1*****1 *****28100-50110-84 ******CORE RETURN *******************30.00******** -30.00
JOB # 1**** 2 *****17171-50020 **********GASKET, INTAKE MA ************42.76 ********85.52
JOB # 1 TOTAL PARTS 390.26 and $1104 for labor plus
05WineLS
May 21, 2017 12:30 AM
ejthomp
May 28, 2016 08:10 PM
mvbls400
Apr 30, 2010 12:23 AM
