Getting a second car- 04 LS430
Scottsdale auto group in mesa has a white '06 for $10,800 that is a better buy. has preferred 18 inch wheels, and no navigation. no accidents, but 5 owners would be a concern. don't know what color you prefer, but between the silver and green I would get the silver. white one in on cars guru by the way.
https://www.cargurus.com/Cars/inventorylisting/viewDetailsFilterViewInventoryListing.action?sourceContext=carGurusHomePage_false_0&entitySelectingHelper.selectedEntity=d565&zip=85006#listing=166587128
I did look at that one but the 5 previous owner and higher mileage made me bypass it. However, the white and those wheels are my preferred choice.
Lexus shows it as a FL car. And it was in AZ in 2014 where it was serviced by a local Lexus dealer.
VIN: JTHBN36F765030369
Filter History By Year
ALLAll 2014 2012 2010 2009 2008 2007 2006 2005
63332 MILES
DATE: 01/14/2014
43065 MILES
DATE: 06/20/2012
42145 MILES
DATE: 03/19/2010
36547 MILES
DATE: 07/27/2009
36477 MILES
DATE: 05/18/2009
25758 MILES
DATE: 10/09/2008
22063 MILES
DATE: 08/28/2008
20111 MILES
DATE: 07/29/2008
19461 MILES
DATE: 01/29/2008
15553 MILES
DATE: 04/17/2007
10823 MILES
DATE: 11/09/2006
6601 MILES
DATE: 06/19/2006
5652 MILES
DATE: 05/01/2006
4410 MILES
DATE: 04/14/2006
3109 MILES
DATE: 03/27/2006
20 MILES
DATE: 08/31/2005
63332 MILES
DATE: 01/14/2014
REPAIR# 0131075REPORTED BY: Lexus of Chandler
SERVICE: 60K MILE SVCDESCRIPTION: 60K MILE SVC ~ ~CUSTOMER REQUESTS A 60K MILE SERVICE ~ ~RECOMMENDED MAINTENANCE ~ ~60,000 MILE SVC.
SERVICE: OTHERSDESCRIPTION: OTHERS ~ ~GUEST STATES THAT THE BRAKE LIGHT IS ON ~ ~ ~ ~NEEDS BRAKES FRONT AND REAR PROVIDED ESTIMATE CUSTOMER DECLINED.OTHERS ~ ~GUEST REQUEST TO HAVE THE SPARK PLUG REPLACED DUE TO 60K ~ ~MAINTENANCE SCHEDULE ~ ~REPLACED SPARK PLUGS
SERVICE: RED FRONT/REAR BRAKEDESCRIPTION: RED FRONT/REAR BRAKE ~ ~FRONT/REAR BRAKE PAD LINING AT LESS THAN 20% REMAINING. ~ ~SSK INSPECTION ~ ~CUSTOMER DECLINED.
SERVICE: YEL TIREDESCRIPTION: YEL TIRE ~ ~TIRE TREAD DEPTH IS BETWEEN 3MM TO 5MM. ~ ~SSK INSPECTION ~ ~RECOMMEND RECHECKING AT NEXT SERVICE
43065 MILES
DATE: 06/20/2012
REPAIR# 0269616REPORTED BY: Arrowhead Lexus
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~LUBE OIL AND FILTER ~ ~ ~ ~LUBE OIL AND FILTER
42145 MILES
DATE: 03/19/2010
REPAIR# 0202293REPORTED BY: Arrowhead Lexus
SERVICE: BATTERY/COIL SPK PLUG BATTERY/COIL SPK PLUGDESCRIPTION: BATTERY/COIL SPK PLUG ~ ~CUSTOMER STATES NO CRANK NO START BATTERY REPLACED 7/25/09, MILES 36547, RO #181805 ~ ~BATTERY FAILED LOAD TEST ~ ~REPLACED BATTERY
36547 MILES
DATE: 07/27/2009
REPAIR# 0181805REPORTED BY: Arrowhead Lexus
SERVICE: INSPECT BATTERY CHARGE LEVEL INSPECT BATTERY CHARGE LEVELDESCRIPTION: INSPECT BATTERY CHARGE LEVEL ~ ~CUSTOMER STATES WONT START ROADSIDE ~ ~BATTERY FAILED LOAD TEST RO #214907, DATE 01/29/08 ~ ~REPLACED BATTERY
36477 MILES
DATE: 05/18/2009
REPAIR# 0176119REPORTED BY: Arrowhead Lexus
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~LUBE OIL AND FILTER ~ ~ ~ ~LUBE OIL AND FILTERNON WARRANTABLE OPERATION CODE ~ ~CUSTOMER REQUEST AIR FILTER REPLACEMENT ~ ~ ~ ~REPLACED ENGINE AIR FILTERNON WARRANTABLE OPERATION CODE ~ ~REPLACE A/C AIR FILTER. ~ ~ ~ ~REPLACED A/C FILTER(S)
25758 MILES
DATE: 10/09/2008
REPAIR# 0245921REPORTED BY: Lexus of North Miami
SERVICE: 10000 MILE SERVICE NON WARRANTY-NON OEMDESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS 25000 MILE SERVICE. INCLUDES OIL AND FILTER CHANGE, ROTATE AND BALANCE 4 TIRES, CORRECT ALL FLUID LEVELS, LUBE HINGES, LOCKS AND WEATHER- STRIPS, TIGHTEN DRIVE BOOTS, DUST COVERS, BALL JOINTS, INSPECT BRAKE LININGS, REMOVE AND CLEAN DEBR ~ ~ ~ ~COMPLETED 25000 MILE SERVICE. THANK YOU FOR SERVICING AT COUNTYLINE LEXUS.
22063 MILES
DATE: 08/28/2008
REPAIR# 0242729REPORTED BY: Lexus of North Miami
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~BACK GLASS CANT SEE CLEARLY.....OR LINES INSTALL TINTS.....$145.00 ~ ~ ~ ~FELIX TINTS
20111 MILES
DATE: 07/29/2008
REPAIR# 0240638REPORTED BY: Lexus of North Miami
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~AC VENT PASS SIDE DONT MOVE SIDE TO SIDE.....CENTER ~ ~BAD CONTACT ~ ~INSTALLED NEW RIGISTOR ASSEMBLY.... T
19461 MILES
DATE: 01/29/2008
REPAIR# 0214907REPORTED BY: Lexus of Pembroke Pines
SERVICE: OTHERS OTHERSDESCRIPTION: OTHERS ~ ~CHECK BATTERY AS PER AVO ~ ~TESTED BATTERY-DEAD BATTERY ~ ~REPLACED BATTERY
15553 MILES
DATE: 04/17/2007
REPAIR# 0183265REPORTED BY: Lexus of Pembroke Pines
SERVICE: 10000 MILE SERVICE NON WARRANTY-NON OEMDESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS OIL AND FILTER CHANGE $34.95 + TAX ~ ~INCLUDES REPLENISHMENT OF ALL FLUIDS & TIRE PRESSURE CORRECTION ~ ~OIL & FILTER CHANGE W/ LUBE 2006
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~ROTATE AND BALANCE TIRES $59.95 + TAX ~ ~ ~ ~BALANCE & ROTATE TIRES ALL 4 TIRES
10823 MILES
DATE: 11/09/2006
REPAIR# 0165732REPORTED BY: Lexus of Pembroke Pines
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~CUSTOMER REQUESTS OIL AND FILTER CHANGE ~ ~PER COUPON SPECIAL 19.95 ~ ~COMPLETED AS REQUESTED. THANK YOU.
SERVICE: TIRE ROTATIONDESCRIPTION: TIRE ROTATION ~ ~ROTATE TIRES ~ ~ ~ ~ROTATE TIRES ALL
6601 MILES
DATE: 06/19/2006
REPAIR# 0150834REPORTED BY: Lexus of Pembroke Pines
SERVICE: FRONT/REAR BODYDESCRIPTION: FRONT/REAR BODY ~ ~REAR SUNSHADE MAKES SQUEAK NOISE GOING UP AND DOWN ~ ~ ~ ~LUBED
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~CUSTOMER REQUESTS OIL AND FILTER CHANGE $19.95 + TAX ~ ~PER COUPON SPECIAL 19.95 ~ ~COMPLETED AS REQUESTED. THANK YOU.
5652 MILES
DATE: 05/01/2006
REPAIR# 0145839REPORTED BY: Lexus of Pembroke Pines
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~SEVERE VIBRATION WHILE DRIVING SOP IN SEE STEVE ~ ~SPARE TIRE HAS EXCESSIVE ROAD FORCE ~ ~04/50 REPLACEDSPARE TIRE OLD DOT#EU1K4MDR4405 NEW DOT#EU1K4MDR4105 10/32 DEPTH
4410 MILES
DATE: 04/14/2006
REPAIR# 0118741REPORTED BY: Nalley Lexus - Roswell
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~CUSTOMER IS COMING IN FROM A TRIP. CUSTOMER STATES NOTICING VIBRATION ON HIGHWAY. PLEASE BALANCE ALL FOUR WHEELS. =-=-=-=-=-=-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=- =- ~ ~EXCESSIVE ROAD FORCE. OUT OF BALCANCE =-=-=-=-=-=-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=- =- ~ ~REBALANCED ALL FOUR WHEELS. STILL VIBRATION FELT. SEE CONDITION TWONON WARRANTABLE OPERATION CODE ~ ~CUSTOMER STATES GETTING VIBRATION AT HIGHWAY SPEEDS. =-=-=-=-=-=-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=- =- ~ ~EXCESSIVE ROAD FORCE VARIATION.=-=-=-=-=-=-=-=-=-= -=-=-=-=-= =-=-=-=-=-=-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=- =- ~ ~REPLACED THE RIGHT FRONT TIRE. REPLACED THE LEFT REAR TIRE. TEST DROVE VEHICLE TO CONFIRM VIBRATION WAS ELIMINATED
SERVICE: NON WARRANTABLE OPERATION CODE NON WARRANTABLE OPERATION CODEDESCRIPTION:
3109 MILES
DATE: 03/27/2006
REPAIR# 0142120REPORTED BY: Lexus of Pembroke Pines
SERVICE: 5000 MILE SERVICEDESCRIPTION: 5000 MILE SERVICE ~ ~5000 MILE SERVICE ~ ~OIL AND FILTER CHANGE, LUBE HINGES, LOCKS & WEATHERSTRIPS, ROTATE TIRES, INSPECT AIR FILTER, INSPECT DRIVE BELTS, ADJUST TIRE PRESSURE AND CHECK FOR WEAR, CORRECT ALL FLUID LEVELS, INSPECT CHASSIS AND SUSPENSION BOLTS, VERIFY PROPER OPERATION DURING ROAD ~ ~COMPLETED 5000 MILE SERVICE. THANK YOU FOR YOUR BUSINESS!
SERVICE: FRONT/REAR BODYDESCRIPTION: FRONT/REAR BODY ~ ~GEAR SHIFT VIBRATES WHEN SHIFTING INTO GEAR ~ ~ ~ ~ADJUSTED GEAR SHIFT
20 MILES
DATE: 08/31/2005
REPAIR# 0706408REPORTED BY: Lexus of West Kendall
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDESDESCRIPTION: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~ ~PDI
I went to check out the silver LS and I'm not feeling it. It has several deep scratches on the hood and trunk and rear bumper. The guy that is selling is like a car broker so he has other cars that he's selling it and this LS was all dusty and the engine was dusty as well. It did ride pretty smooth compared to my GS but that's a given since my GS is a F Sport and it has low profile tires.
I'm going to check that white one and see if they have a CarFax for it.
Here's another 06 white one with the 18" wheels and 107k miles.
https://www.kbb.com/cars-for-sale/454918938/?totalresults=9&index=8&searchtype=used&atcmake=lexus&atcmodel=ls%20430&zipcode=&distance=75&tab=keydetails
It had some damage body damage in 2006 when it had 5k miles and it looks like it's had frequent oil changes.
Lexus shows:
VIN: JTHBN36F865035791
103255 MILES
DATE: 10/26/2016
REPAIR# 1005359
REPORTED BY:
SERVICE: USED CAR SAFETY INSP - USED CAR
DESCRIPTION: USED CAR SAFETY INSP - PASSENGER SIDE MIRROR ASSEMBLY OUTTER HOU SING FOR MIRROR ASSEMBLY HAS A H OLE IN HOUSING PLEASE PROVIDE AN EST FOR MIRROR ASSEMBLY AND IF POSSIBLE MIRROR HOUSING ONLY .-- --------COLOR IS WHITE ~ ~ ~ ~EST ONLY DECLINED96660 MILES
DATE: 05/13/2016
REPAIR# 0757746
REPORTED BY: Superstition Springs Lexus
SERVICE:
DESCRIPTION: ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN A ~ ~ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN ANY VEHICLE. IF FOUND DOUBLE STACKED,IMPROPER FIT OR WRONG FLOOR MAT, IT WILL BE REMOVED AND PLACED IN TRUNK AREA FOR SAFETY. ~ ~NEVER INSTALL FLOOR MAT UPSIDE DOWN DRIVERS AREA. AFTERMARKET OR NOT, NEVER STACK FLOOR MATS.ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN A
SERVICE: MULTI-POINT VISUAL INSPECTION, FULL VEHICLE INSPECTION
DESCRIPTION: MULTI-POINT VISUAL INSPECTION, FULL VEHICLE INSPECTION ~ ~MULTI-POINT VISUAL INSPECTION, FULL VEHICLE INSPECTION ~ ~ ~ ~96660 PERFORMED MULTI POINT INSPECTION
SERVICE: OIL CHANGE
DESCRIPTION: OIL CHANGE ~ ~OIL CHANGE ~ ~ ~ ~96660 30 PERFORMED LOF59145 MILES
DATE: 10/31/2013
REPAIR# 0127452
SERVICE: AC DUST FILTER
DESCRIPTION: AC DUST FILTER ~ ~REPLACE AC FILTER AS RECOMMENDED ~ ~ ~ ~AIR CONDITIONING CABIN FILTER, FRONT, R&R (IF EQUIPPED) 01/0
SERVICE: LOC.COM
DESCRIPTION: LOC.COM ~ ~INTERNET SERVICE SPECIAL 10% OFF ~ ~... ~ ~...
SERVICE: R&R ENG AIR FILTER
DESCRIPTION: R&R ENG AIR FILTER ~ ~REPLACE ENGINE AIR FILTER ~ ~ ~ ~AIR FILTER, R&R 01/06
SERVICE: RED TIRE
DESCRIPTION: RED TIRE ~ ~TIRE TREAD DEPTH AT 3MM OR LESS. NEEDS REPLACEMENT ~ ~RECOMMEND TIRES AND ALIGNMENT ~ ~CUSTOMER DECLINED.
SERVICE: RED WIPER OPERATION
DESCRIPTION: RED WIPER OPERATION ~ ~WIPER OPER FELL BELOW FACTORY REQUIREMENTS. ~ ~RECOMMEND REMAINDER OF 60K ITEMS (WIPERS, BRAKE FLUSH) RECOMMEND FRONT LOWER PIVOT BUSHINGS - TORN ~ ~CUSTOMER DECLINED.
SERVICE: SPG OIL CHANGE
DESCRIPTION: SPG OIL CHANGE ~ ~SERVICE GUIDE OIL CHANGE W/ FILTER ~ ~SERVICE GUIDE OIL CHANGE W/ FILTER ~ ~OIL CHANGE & MPI54623 MILES
DATE: 08/23/2012
REPAIR# 0106939
SERVICE: LOF 10% OFF MAILER
DESCRIPTION: LOF 10% OFF MAILER ~ ~LOF 10% OFF MAILER
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~CUSTOMER REQUESTS LUBE, OIL AND FILTER CHANGE. ~ ~NORMAL VEHICLE MAINTENANCE. ~ ~OIL & FILTER CHANGE W/ LUBE 2006
SERVICE: OTHERS
DESCRIPTION: OTHERS ~ ~CUSTOMER NOTED TIRES ROTATED AT OUTSIDE SOURCE ~ ~ ~ ~.
SERVICE: RED NEEDED SERVICES
DESCRIPTION: RED NEEDED SERVICES ~ ~ADVISE ON NEEDED SERVICES - ACTION REQUIRED. ~ ~SSK INSPECTION. ~ ~CUSTOMER DECLINED.
SERVICE: RED TIRE
DESCRIPTION: RED TIRE ~ ~TIRE TREAD DEPTH AT 3MM OR LESS. NEEDS REPLACEMENT ~ ~SSK INSPECTION ~ ~CUSTOMER DECLINED.49549 MILES
DATE: 06/03/2011
REPAIR# 0088048
SERVICE: MAILER DISCOUNT
DESCRIPTION: MAILER DISCOUNT ~ ~MAILER DISCOUNT APPLIED 11% OFF OIL CHANGE ~ ~ ~ ~K
SERVICE: OTHERS
DESCRIPTION: OTHERS ~ ~TIRES ROTATED AT OUTSIDE SOURCE ~ ~ ~ ~K
DESCRIPTION: RED FRONT/REAR BRAKE ~ ~FRONT/REAR BRAKE PAD LINING AT LESS THAN 20% REMAINING. ~ ~FOUND FRONT BRAKES AT 2.5MM AND SENSOR TOUCHING, REAR BRAKES AT 3MM / RECOMMEND FRONT AND REAR BRAKE JOBS COMPLETE WITH NEW PADS, TURNING OF ROTORS, AND REPLACEMENT OF CALIPER BOLTS (NOTE, MAY NEED NEW FRONT SENSOR IF BRAKES AT FRONT DONE /NEED TO INSPECC ~ ~CUSTOMER DECLINED.
DESCRIPTION: SPG OIL CHANGE ~ ~SERVICE GUIDE OIL CHANGE W/ FILTER ~ ~SERVICE GUIDE OIL CHANGE W/ FILTER ~ ~REGULAR OIL CHANGE44799 MILES
DATE: 10/04/2010
REPAIR# 0078468
DESCRIPTION: MAILER DISCOUNT ~ ~MAILER DISCOUNT APPLIED 12% OFF OIL CHANGE ~ ~ ~ ~SEE ADVISOR
SERVICE: OTHERS
DESCRIPTION: OTHERS ~ ~TIRES ROTATED AT OUTSIDE SOURCE ~ ~ ~ ~NO ROTATION AT THIS TIME.
DESCRIPTION: R&R ENG AIR FILTER ~ ~REPLACE ENGINE AIR FILTER ~ ~RECOMENDED MAINTENANCE ~ ~AIR FILTER, R&R 01/06
SERVICE: YEL FRONT/REAR BRAKE
DESCRIPTION: YEL FRONT/REAR BRAKE ~ ~FRONT/REAR BRAKE PAD LINING AT 20-50% REMAINING. ~ ~SSK INSPECTION ~ ~RECOMMEND RECHECKING AT NEXT SERVICE
SERVICE: YEL NEEDED SERVICES
DESCRIPTION: YEL NEEDED SERVICES ~ ~RECOMMEND RECHECKING AT NEXT SERVICE ~ ~SSK INSPECTION. ~ ~CUSTOMER DECLINED.
SERVICE: YEL TIRE
DESCRIPTION: YEL TIRE ~ ~TIRE TREAD DEPTH IS BETWEEN 3MM TO 5MM. NEEDS ATTENTION SOON ~ ~SSK INSPECTION ~ ~RECOMMEND RECHECKING AT NEXT SERVICE39377 MILES
DATE: 09/15/2009
REPAIR# 0062898
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~TIRES ROTATED AT OUTSIDE SOURCE ~ ~ ~ ~TIRES ROTATED AT AN OUTSIDE SOURCE
DESCRIPTION: SPG OIL CHANGE ~ ~SERVICE GUIDE OIL CHANGE W/ FILTER ~ ~SERVICE GUIDE OIL CHANGE W/ FILTER ~ ~REGULAR OIL CHANGE TIRES AND BRAKE MEASUREMENTS: LEFT FRONT CENTER 6 RIGHT FRONT CENTER 6 LEFT FRONT EDG 6 RIGHT FRONT EDG 6 LEFT REAR CENTER 6 RIGHT REAR CENTER 6 LEFT REAR EDG 6 RIGHT REAR CENTER 6 BRAKE MEASUREMENTS IN MILLIMETERS, PAD REMAINING FRONT34716 MILES
DATE: 02/02/2009
REPAIR# 0053870
SERVICE: OTHERS
DESCRIPTION: OTHERS ~ ~CLIENT STATES THAT TIRES ARE ROTATED AT OUTSIDE SOURCE. DECLINED AT THIS TIME. ~ ~ ~ ~ROTATION DECLINED
DESCRIPTION: SPG OIL CHANGE ~ ~SERVICE GUIDE OIL CHANGE W/ FILTER ~ ~SERVICE GUIDE OIL CHANGE W/ FILTER ~ ~OIL AND FILTER CHANGE - FRONT AND REAR TIRES AT 6 ON EDGES, 8 AT CENTERS FRONT BRAKES AT 5MM, REAR BRAKES AT 5MM29890 MILES
DATE: 06/20/2008
REPAIR# 0044971
DESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS 30000 MILE SERVICE DO NOT ROTATE AND BALANCE TIRES WILL HAVE REPLACED ELSEWHERE ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~30000 MILE SERVICE PERFORMED TIRE TREAD REMAINING IN MILLIMETERS LEFT FRONT EDGE2 RIGHT FRONT EDG1 LEFT FRONT CTR4RIGHT FRONT CTR3 LEFT REAR EDG0RIGHT REAR EDG1 TIRE TREAD REMAINING IN MILLIMETERS2 BRAKE MEASUREMENTS IN MILLIMETERS, PAD REMAINING FRONT5RE
SERVICE: DISTRIBUTOR/HDLIGHT/T. SGNL
DESCRIPTION: DISTRIBUTOR/HDLIGHT/T. SGNL ~ ~CIG LIGHTER IS INOP ~ ~SHORT IN CIG LIGHTER FULS ~ ~REPLACE CIG LIGHTER FULS FP# 90080-8202224784 MILES
DATE: 12/03/2007
REPAIR# 0036716
DESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS 25000 MILE SERVICE ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE - DID NOT ROTATE OR BALANCE WHEELS AND TIRES - REC. 4 TIRES AND ALIGNMENT ~ ~25000 MILE SERVICE PERFORMED -R&B TIRE TREAD REMAINING IN MILLIMETERS LEFT FRONT EDGE2 RIGHT FRONT EDG1 LEFT FRONT CTR5RIGHT FRONT CTR4 LEFT REAR EDG3RIGHT REAR EDG2 LEFT REAR CTR4RIGHT REAR CTR3 BRAKE MEASUREMENTS IN MILLIMETERS, PAD REMAINING FRONT7REAR20080 MILES
DATE: 05/31/2007
REPAIR# 0028827
DESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS 20000 MILE SERVICE ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~20000 MILE SERVICE PERFORMED TIRE TREAD IN REMAINING MILLIMETERS LEFT FRONT EDGE3.5 RIGHT FRONT EDG3.5 LEFT FRONT CTR5RIGHT FT CTR5 LEFT REAR EDG3.5RIGHT REAR EDG3.5 LEFT REAR CTR5RIGHT REAR CTR5 BRAKE MEASUREMENTS IN MILLIMETERS, PAD REMAINING FRONT7REAR
SERVICE: AIR CONDITIONING
DESCRIPTION: AIR CONDITIONING ~ ~CUSTOMER NOTED BAD SMELL FROM AC SYSTEM - ADVISE - DISINFECT ~ ~ ~ ~DISINFECTED AC SYSTEM, AC FILTER REPLACED LAST SERVICE. SEE ADVISOR.15079 MILES
DATE: 01/24/2007
REPAIR# 0023587
SERVICE: 15000 MILE SERVICE NON WARRANTY
DESCRIPTION: 15000 MILE SERVICE NON WARRANTY ~ ~CUSTOMER REQUESTS 15000 MILE SERVICE - WITH AC AND ENGINE FILTERS -- - COUPON ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~15000 MILE SERVICE PERFORMED TIRE TREAD REMAINING IN MILLIMETERS LEFT FRONT EDGE4 RIGHT FRONT EDGE4 LEFT FRONT CTR5.5RIGHT FRONT CTR5.5 LEFT REAR EDGE4RIGHT REAR EDGE4 LEFT REAR CTR5.5RIGHT REAR CTR5.5 BRAKE MEASUREMENTS IN MILLIMETERS, PAD REMAINING FRON
SERVICE: MISC
DESCRIPTION: MISC ~ ~CUSTOMER NOTED NAVIGATION SYSTEM DOES NOT SEEM ACCURATE - WILL NOT GET TO CORRECT POINT ~ ~CONFIRM DESTINATION SETTINGS. CHECK FOR ANY FAULTS OR CODES, NONE PRESENT. NO RELEVANT TSIB'S OR UPGRADES. ~ ~SEE ADVISOR FOR PRINT OUT OF SYSTEM LIMITATIONS. NEED DETAILED INFO IF SYMPTOM IS OUTSIDE OF DESIGN LIMITATIONS. NEWER SOFTWARE VERSION IS AVAILABLE BUT THIS WILL NOT ALTER FUNCTIONALITY. SEE ADVISOR OR OWNERS MANUAL FOR MORE INFORMATION.
SERVICE: OTHERS
DESCRIPTION: OTHERS ~ ~CUSTOMERNOTED HESITATION ON ACCELERATION ~ ~TEST DRIVE FOR DRIVABILITY, ALL OK. CHECK FOR ANF FAULTS OR CODES, NONE PRESENT. NO UPDATES AVAILABLE. ~ ~ENGINE & TRANS OPERATING AS DESIGNED. ALL DRIVABILITY CHARACTERISTICS WITHIN OPERATING PARAMETERS.13975 MILES
DATE: 12/15/2006
REPAIR# 0022167
DESCRIPTION: INSPECT BATTERY CHARGE LEVEL ~ ~CUSTOMER NOTED VEHICLE HAD TO BE JUMP STARTED ~ ~BATTERY FAILED LOAD TEST ~ ~TESTED ADN REPLACED BATTERY 288074142 6O3P10042 MILES
DATE: 08/21/2006
REPAIR# 0017876
SERVICE: MISC
DESCRIPTION: MISC ~ ~CUSTOMER NOTED BOTH FRONT SEAT VENTILATORS DO NOT SEEM COOL ~ ~ ~ ~CHECK SEAT VENTILATORS/BOTH OPERATE NORMALLY
SERVICE: ROTATE & BALANCE
DESCRIPTION: ROTATE & BALANCE ~ ~ROTATE AND BALANCE 4 TIRES ~ ~ ~ ~1.2 HRS ROT/BAL TIRE TREAD REMAINING IN MILLIMETERS LEFT FRONT EDGE4 RIGHT FRONT EDG4 LEFT FRONT CTR6RIGHT FT CTR6 LEFT REAR EDG4RIGHT REAR EDG4 LEFT REAR CTR6RIGHT REAR CTR6 BRAKE MEASUREMENTS IN MILLIMETERS, PAD REMAINING FRONT9REAR84923 MILES
DATE: 04/04/2006
REPAIR# 0013311
SERVICE: 5,000 MILE SERVICE
DESCRIPTION: 5,000 MILE SERVICE ~ ~CUSTOMER REQUESTS 5000 MILE SERVICE ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~5000 MILE SERVICE PERFORMED 001050 TIRE TREAD REMAINING IN MILLIMETERS LEFT FRONT EDGE5.0 RIGHT FRONT EDG5.0 LEFT FRONT CTR6.0RIGHT FT CTR6.0 LEFT REAR EDG6.0RIGHT REAR EDG6.0 LEFT REAR CTR6.0RIGHT REAR CTR6.0 BRAKE MEASUREMENTS IN MILLIMETERS, PAD REMAIN
DESCRIPTION: DISTRIBUTOR/HDLIGHT/T. SGNL ~ ~CUSTOMER NOTED DAMAGE AT RIGHT FRONT LOWER ROCKER PANL - EST. OF 450.00 GIVEN 3/28 DEALERS CHOICE - CUSTOMER TO CALL AND SCHEDULE - DAMAGE APPEARS TO BE FROM FLYING OBJECT --CLAIM # 486943-28 // USAA # 486943 --WOUDL NEED TO PAINT / BLEN 3 LOWER PANEL DOO ~ ~ ~ ~REPAIRED RIGHT FRONT LOWER CLADDING DAMAGE AS NEEDED PER ESTIMATE (CONDITIONED,PAINT, BLEND)12 MILES
DATE: 10/18/2005
REPAIR# 0089714
REPORTED BY: Lexus of Las Vegas
SERVICE: PRE-DELIVERY INSPECTION SERVICE
DESCRIPTION: PRE-DELIVERY INSPECTION SERVICE ~ ~PRE-DELIVERY INSPECTION SERVICE ==SEE PETER FOR KEYS ~ ~PDI ~ ~PRE-DELIVERY INSPECTION SERVICE
Lexus shows:
103255 MILES
DATE: 10/26/2016
REPAIR# 1005359
REPORTED BY:
DATE: 05/13/2016
REPAIR# 0757746
SERVICE:
SERVICE: OIL CHANGE
DATE: 10/31/2013
REPAIR# 0127452
SERVICE: LOC.COM
SERVICE: RED TIRE
DATE: 08/23/2012
REPAIR# 0106939
SERVICE: OTHERS
SERVICE: RED TIRE
DATE: 06/03/2011
REPAIR# 0088048
SERVICE: OTHERS
DATE: 10/04/2010
REPAIR# 0078468
SERVICE: OTHERS
SERVICE: YEL TIRE
DATE: 09/15/2009
REPAIR# 0062898
DATE: 02/02/2009
REPAIR# 0053870
SERVICE: OTHERS
DATE: 06/20/2008
REPAIR# 0044971
DATE: 12/03/2007
REPAIR# 0036716
DATE: 05/31/2007
REPAIR# 0028827
DATE: 01/24/2007
REPAIR# 0023587
SERVICE: MISC
SERVICE: OTHERS
DATE: 12/15/2006
REPAIR# 0022167
DATE: 08/21/2006
REPAIR# 0017876
SERVICE: MISC
DATE: 04/04/2006
REPAIR# 0013311
DATE: 10/18/2005
REPAIR# 0089714
So I went to check out the Cypress Pearl and it was pristine like the pics showed it. Definitely loved the ride compared to my GS. Lots more quiet and the A/C is way colder than GS and the LS wasn't even on the lo setting. The dealer didn't budge on price so it would come out to 15.5k out the door.
I told him if he's ever wiling to come down to the 12 or 13k out the door to give me a call.
So the search continues haha.
although the white car has 30,000 more miles, lots of things are 2 years newer. for instance all the rubber seals that will wear out and the carpets and dash are 2 years newer. and the '04 model has more issues than the '06 model year. some '04 have issues with sunscreens and cupholders that I have not heard about on the newer -06's. I would not be concerned with the mileage on any of those and would get the one that I would like to see in my driveway. when I bought my car it was the most LS430 that I could afford at the time. it just happens to be brown. I would prefer white or silver, and almost traded up to a CL version that was gold a few years ago. you should consider what you want, ML, CL, UL or base/premium almost as much as color. just my opinion
I do want ML and ca either go with nav or no nav since my GS has navigation. My top choice is white with 18's.
Hang in there. The right car will come along and honestly I wouldn't be surprised if you hear back from the Cypress Pearl dealer. Unless he paid too much in the first place he will probably call you back. However, you're doing the right thing and moving on. If it's meant to be it will happen.
I'll also say my '04 didn't have any more issues that you wouldn't find on a another 13 yr old car. An '04 LS, in general, is a quality built car.
Yeah I pretty much agree.....I filter out all but 2006, and honestly I think the avg. price has dropped 2k since I purchased last OCT.....and, no joke, the mileage is the same. I think for many people except us on the forum, this is an old car and not necessarily a daily driver. Most people would consider 2006 old. So imho the longer you wait, the more the price falls, with mileage not increasing at 12k/yr. So it only gets sweeter and sweeter. If it were me I'd like a CL for the laminated side glass, and the washers are cool, soft close doors I'll take 'em too....me I would want that aniline leather, probably not that common but there is something to be said on finding what you want. Why pay thousands for something you're just ok with? my .02
This 2004 Sport just pop up:
https://phoenix.craigslist.org/evl/cto/6174015241.html
What do you guys think?
Find out more about the service history. Pull the details and/or ask to see the service records, especially for the timing belt. You have to see what else was done with the timing belt like the water pump and/or tensioner. Price is definately at the top end for the year and mileage but it could be worth it and/or they might come down a little on the price.
Looks like it's a sport suspension from the pics. You should confirm that as well.
