Blast pipes
Subscribe
Jun 7, 2016 | 05:46 AM
I'm sure someone here has done them. If so
How is the does it sound?
Are you happy with it?
How is the droning?
Reply 0
Jun 7, 2016 | 06:56 AM
So your talking about adding a one to two foot section of pipe on the stock mufflers???? Ummmm hate to brake it to you guy but go outside and rev your car and thats as much sound as you will get from your "blast pipes".
Reply 0
Jun 7, 2016 | 09:23 AM
Lol don't mufflers restrict sound? So assuming with them removed the sound decibels will increase? I deleted my resonators and my car picked up a low rumble. Nothing to crazy.
Reply 0
Jun 7, 2016 | 10:10 AM
If you remove the mufflers the car will be a lot more louder. The LS430 mufflers have super sound deadening features, but for it to get crazy loud you would have to remove the middle resonator.
I personally removed the resonators after the cats, replaced with straight pipe.
Then removed the middle resonator, and replaced with an "x-pipe", but left the stock mufflers.
I then installed an electric cutout that is triggered via a remote to open and close the cutout. That way, when the cutouts are closed, the exhaust has to go through the muffler(therefore deadening the sound, leaving the car almost sounding stock)
But when I open the cutouts, hell is unleashed.
Oh, and I did change my mufflers to Borla's recently..
Reply 0
Jun 7, 2016 | 10:58 AM
How's the car sound with the Borla mufflers? Any drone?
Reply 0
Jun 7, 2016 | 11:50 AM
"on the stock mufflers???" Was what i said thats what a screamer pipe is, a large section of pipe off the muffler. Its based off of japenese bosuko styling you talking about muffler deletes which is completely different.
Reply 0
Jun 7, 2016 | 01:56 PM
I was thinking about doing that also king... what brand e cut outs are you using. I don't wanna get a cheap brand. I'm not even sure if there is a good brand lol
Reply 0
Jun 7, 2016 | 05:09 PM
All e cut outs die eventually if there electronic the heat from the exhaust kills the electronics, your much better off doing a x pipe were the third cat is and then do straight piping from the x pipe and no mufflers. There is a video or two on YouTube with ls's with just a muffler delete done.
Reply 0
Jun 9, 2016 | 05:18 PM
Quote: I was thinking about doing that also king... what brand e cut outs are you using. I don't wanna get a cheap brand. I'm not even sure if there is a good brand lol
I got the QTP cutouts, and for almost 2 years now, they have been trouble free. They are an excellent company with very high quality products. Would definitely recommend them.
Especially since the cutout I got from them was a rather smaller cutout, they call it "low profile", because of the small space that is available under the car, you will need a smaller sized cutout, and so that it also never scrapes and stays very high off the ground.
Reply 0
Jun 9, 2016 | 05:23 PM
Quote: All e cut outs die eventually if there electronic the heat from the exhaust kills the electronics, your much better off doing a x pipe were the third cat is and then do straight piping from the x pipe and no mufflers. There is a video or two on YouTube with ls's with just a muffler delete done.
If you install the cutout correctly, and make sure the wiring is all done neatly and clean you will have zero issues in the future.
Reply 0
Jun 9, 2016 | 05:42 PM
Quote: If you install the cutout correctly, and make sure the wiring is all done neatly and clean you will have zero issues in the future.
Idk man i tried cut outs on my eclipse for a down pipe/screamer pipe and they kept dying because of the heat.
Reply 0
Jun 10, 2016 | 09:13 AM
Thanks for the info king. My car is pretty low. And my drive way is really slanted. Might have to go to bags.
Reply 0
Subscribe
