Low tire warning
Old Mar 8, 2016 | 08:09 AM
lexman52's Avatar
lexman52
Default Low tire warning
I have reset this a couple of times from under the dash near the gas peddle. About 10 miles latter it comes back on . Whats next to do?
Old Mar 8, 2016 | 09:19 AM
JffGRY706's Avatar
JffGRY706
you are not holding your tongue right. stick your tongue out all the way and over to the left when you reset it. do you have OEM wheels? if you have some aftermarket wheels then you are just out of luck. if all else fails read the directions. my owners book says multiple steps before resetting. dealership takes care of this when rotating tires, ask them the correct procedure. it is not just pushing reset.
Old Mar 8, 2016 | 12:28 PM
Anthony81's Avatar
Anthony81
You have to hold it down for 10 seconds or so until it says initialize.
Old Mar 8, 2016 | 12:29 PM
lexman52's Avatar
lexman52
Smart *** If i rotate tires or change tires the reset DOES take of the problem.The more i think of it maybe it's a bad sensor.
Old Mar 8, 2016 | 12:31 PM
lexman52's Avatar
lexman52
Yea i did hear that about holding it in for 20 sec, I tried it for 30 sec and it did nothing.
Old Mar 8, 2016 | 07:38 PM
Jabberwock's Avatar
Jabberwock
Perform a forum search on your post's title - "low tire warning". There are multiple previous threads that address this issue.
Old Mar 9, 2016 | 04:05 AM
rkw77080's Avatar
rkw77080
These may help...
File Type: pdf
File Type: pdf
Old Mar 9, 2016 | 05:24 AM
lexman52's Avatar
lexman52
Thanks rkw that did the trick.
Old Mar 9, 2016 | 06:12 AM
XJSFan's Avatar
XJSFan
I have had this on other cars and if I inflate the tires 10PSI over recommended cold PSI, then lower to 2 PSI over, then the light goes off after driving... Its worth a shot. Good luck.
daryll40
RX - 4th Gen (2016-2022)
46
Apr 7, 2022 06:19 AM
dlap
Apr 8, 2012 07:58 PM
MarshalWeb
Jul 2, 2007 10:13 AM
Kyosuke86
Jan 7, 2006 03:37 AM
JHStrange
Sep 6, 2005 06:04 PM
