Looking for ecm pinout LS430 for knock sensor hack
Old Oct 28, 2016 | 06:58 AM
  #46
DavidinCT's Avatar
DavidinCT
Originally Posted by rkw77080
Here's some info on P0174 and P0171. The codes indicate that your engine is running too lean. Please take a look at Post #6 of this thread, I suspect the symptom may very well be the result of re-routing the one knock sensor to both signal inputs to the ECM - your ECM is adjusting the air-to-fuel ratio based on the wrong "knock" signal.
As shown in the illustration below, the LS430 engine fires in the following order 1-8-4-3-6-5-7-2, at 45 degree separation. The knock sensors are like microphones that listens for ignitions of piston "3" and piston "6", that are 45 degree apart. The ECM compares crankshaft position vs. the "knock" and make necessary adjustments to timing and air-to-fuel ratio to remedy abnormality. Your ECM is having difficulty to line up the crankshaft position with the 2 identical knocks that are supposed to be 45 degree apart.
So, on this theary if I reconnect kock 1 these codes would go away and I would just get the Knock Senor 1 code again.?
I noticed that it could be a vacuum hose causing this, as we put the car back together we kind of rushed it, I should double check it before going any deeper on this.
Will these codes coming up (and seeing that it could be adding more air or fuel to the mix), will this cause any perm damage to the car by driving it ? It might be a few days before I can get under the hood.
As for driving the car, the car drives perfect, smooth and full of power.... almost as nice as when it was newer... I just dont want to damage it more by driving it (still need to get to work)
Old Oct 28, 2016 | 10:54 AM
  #47
rkw77080's Avatar
rkw77080
Typically, DTC's do not reset automatically (you will have to clear it manually), so reconnecting the knock sensor will not clear the DTC. However, it will likely to prevent the DTC's to return after you reset them manually.
As you probably already know, the 4-cycle engine operates thru 4 stages: Intake stroke, Compression stroke, Power stroke, and Exhaust stroke. During the Intake stroke, the piston travels downward to draw in fuel/air mixture; then the piston travels upward to compress the fuel mixture in the Compression stroke; at the top of the stroke, the spark plug fires and the explosion pushes the piston downward during the Power stroke; then finally, the piston travels upward to push out the exhaust gas. A "rich" mixture can cause early ignition (before the spark plug fires) - this is also known as "dieseling". In other words, a "rich" fuel mixture will ignite while the piston is on its way up which will apply more force on the piston top. To make matters worse, the Power stroke is supposed to occur when the piston passes the TDC and starting on its way down. Early ignition catches the piston on its way up, essentially slowing its travel and works against the rotation of the crankshaft. On the other hand, "Lean" mixture will not ignite until the spark plug fires and because it's lean, less power is produced.
I don't think running your car lean will cause damage, at least not for a short term (a few weeks or even months). You may experience lower MPG performance. The troubleshooting steps for P0171 and P0174 mention vacuum hose leakage and a few other items to check - I'd start with those items. Meanwhile I would clear the DTC and see if they return.
Old Oct 28, 2016 | 11:57 AM
  #48
DavidinCT's Avatar
DavidinCT
Well the funny thing here is. When had the Knock Sensor issue, I would get the driving problem (as we know) and gas MPG was about 5-7 MPG down with that issue. From doing the "hack" My MPG is up back to where it was. The car performs far better than before (it could be because we cleaned out the whole intake when we had the car apart).
I have been reading about the Symtoms of the P0174 and P0171 codes and I am getting the oppsite of what they claim (big performance hits).
I did clear the DTC after doing the hack and those codes showed up, after driving for about 100 miles, I reset the codes and they came back. I will go and disconnect and re-connect all the vacuum hoses, then try again. This is very possable that when we put the hoses back on, there might of been one or 2 that MIGHT be a little lose.
Thanks again for your advice, I hope it IS a lose hose, I hope I dont have to revierse this hack for now, as the car runs perfect...
Old Jun 6, 2018 | 03:07 AM
  #49
Scootymad's Avatar
Scootymad
Old thread and all that but I'm deep down the rabbit hole doing knock sensors and a starter motor, and trying to find the pinouts for the knock sensors wasn't easy. I had 2 codes relating to knock sensor 2 and an input signal fault, so I've replaced both sensors but now I can probe both the wires back to the plug to check for continuity. I hope my wiring is still sound, I'd rather not have to run new wires back to the ECU. I already have to fix wiring on a coil pack plug and the temp sensor plug.
Old Aug 26, 2018 | 09:33 PM
  #50
Dvotedwun's Avatar
Dvotedwun
Default Knock hack
Hi, can u send me a text pic of the knock hack.
thanks
760 799 0438
Originally Posted by Revrun
I'm trying to perform the bank 1 knock sensor hack to rid myself of code P0325. The hack involves connecting the good signal from the bank 2 knock sensor to the bank 1 wire as it goes into the ecm while leaving the bank 1 sensor disconnected via a cut wire.
I have seen a similar hack performed on the clublexus gs forum.
Has anyone done this? Any ideas on where to find the pinout on the ecm so I can perform this? Any other ideas or thoughts?
Thanks
Old Oct 10, 2018 | 03:51 PM
  #51
LexuslsUlt's Avatar
LexuslsUlt
Does anyone have the ECU pinout for a CA emissions LS430. It seems to be different. Thank you in advance!
Old May 15, 2019 | 08:25 PM
  #52
Alex25's Avatar
Alex25
If anyone wants to do this please send a phone number and I'll text a pic of the splice. Its not that the splicing is difficult, buy knowing what wires to splice was the biggest gamble. I found the information on another forum and followed the lead of quite a few 3UZ folks dealing with some old, hard and broken wiring.
Yes please... have 2002 Lexus SC430... getting P0325... would like to marry to bank 2 and cut out bank 1.
Alex - 1 (949) 230-6775
Old May 31, 2020 | 12:57 AM
  #53
SalvadorG's Avatar
SalvadorG
Default knock sensor by pass
That is exactly what I did. It was a little gamble, but it seems to have paid off. I simply spliced knock sensor 1 and 2 together. Then I cut the "bad" sensor wire going back to the sensor. No check engine lights. Runs just like it should and as easy as it was to execute, wish I would have done it sooner.
The hardest part for me was disassembling the glove box to get to the abs? module that I thought was the ecu. The ecu couldn't be easier to get to. Folks with the similar GS430 are a little more open to experimenting and trouble shooting in this workaround. All I can say now is so far so good.
My cell 9097256940
Interested in how to do what you did to knock sensor bypass
Old Sep 3, 2021 | 03:10 PM
  #54
HILS430's Avatar
HILS430
Anyone still have info on this? Would love to get a diagram 503-821-9644
Old Sep 8, 2021 | 10:28 PM
  #55
dorough21's Avatar
dorough21
Hello, Im taking a shot here and was kinda needing to look at those pics of your splice! Do you still have them? My name is Jeremy 951 880 7717, Thanks
Old Aug 19, 2023 | 04:04 PM
  #56
blkstealthpaid4's Avatar
blkstealthpaid4
Hello. .Can I inbox you for step by step details?I have a 2003 and I am having the p0325
Old Aug 19, 2023 | 04:05 PM
  #57
blkstealthpaid4
Thanks
Can you please tell me the step by step in this fix for my 2003?
Old Aug 20, 2023 | 05:03 AM
  #58
VortecCPI's Avatar
VortecCPI
See here:
https://www.clublexus.com/forums/ls-...sor-issue.html
https://www.clublexus.com/forums/ls-...or-bypass.html
Old May 9, 2024 | 04:46 PM
  #59
E3UZ's Avatar
E3UZ
2nd gear
Default Picture
hey revrun can you please send a picture of the splice to me @ 6502706128 asap
Old May 27, 2024 | 07:50 AM
  #60
shalomhome's Avatar
shalomhome
1st Gear
if it is still available, I would like the photos.
I have a 2002 SC430 that keeps throwing P0325. I have replace both knock sensors with OEM and the brittle wires and connectors about 6” back from the sensors.
strangely, the code will show, engine runs like crap, I turn the car off then restart. While the CEL stays on, it will run normal. Then after driving for a while, the light goes off.
then a day or two later it does it all over again
Andrew
407.399.0292
Marston
Oct 12, 2021 07:42 AM
tdsilk
Nov 30, 2018 05:30 AM
heymatey
Dec 19, 2016 02:16 PM
speedemon
Nov 2, 2013 03:26 PM
SMUChris
Dec 17, 2012 03:50 AM
