Where to put the jack
the jacking point is behind the radiator.i jack up the car behind the front wheel and put a stand under a supportive area then release the jack and put it in position behind the radiator which you will see when the cars jacked up.
This gives me enough clearance to run my floor jack under the car and visibly certain that my jack is not resting against the oil pan. The jack point sits in front of the oil pan so be careful that you do not jack on the pan itself.
For the rear, I put the jack on the pumpkin (or differential housing). Then put the stands between the same two notches near the rocker panel, but at the rear of the car.
This way you can pick up the car one end at a time and slide two jackstands in at a time. I have done the procedure many times with this car and have had no issues.
I have nightmares of meeting my demise by the the car dropping on me, so I am extra paranoid. I will usually put it on the stands and then put the jack under the jacking point so if the stands fail I still have the jack. You can also take the wheels off and shove them under the frame rails so if the car falls it will fall on the tires and not you. Maybe this is overkill, but you can never be too safe in my opinion.
i know figs makes the frame rail support dealios (http://shopfigs.com/v1/index.php?rou...product_id=188). and it looks like you need 4 to hold the car properly while its jacked up.
is there a cheaper alternative? I don't mind spending the money, although if I can spend less money, an get something similar, I am going to do that.
http://www.canadiantire.ca/en/automotive/auto-repair-tools/garage-tools/lifting-equipment/certified-3-ton-jack-kit-0091055p.html?utm_campaign=bazaarvoice&utm_medium=Default&utm_source=AskAndAnswer&utm_content=Default
In Canada these go on sale periodically for $99.99 for the jack and 2 stands. These are beefy and probably overkill. I never jack all four corners only two at a time and never have any problem.
You don't need a frame rail kit, the area to the sides of the thin plastic fin near the jack stand points is frame rail and very strong.
motorheaddown
Apr 20, 2007 11:07 AM
