Any play in your radiator?
Old Sep 17, 2015 | 01:39 PM
Bocatrip's Avatar
Bocatrip
Default Any play in your radiator?
After my raditator install last week, I checked the job out thoroughly after and noticed some play in the radiator when pushing it forward and back. There are two rubber clamps on top that hold it in position. I notice the play more when the car is cold and after warmed up it is considerably less. I am talking about a very slight bit of play. I brought it to the attention of the operations director at Lexus who looked at the car personally and said it was necessary due to back and forth movement of the engine. He showed me numerous places in the enigine where there were also rubber bushings allowing movement. It did make sense to me. If the plastic radiator was totally rigid in place, there would be a better chance of damage down the road from the twisting and vibrations of the engine.
Old Sep 17, 2015 | 07:56 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
i dont have any play in mine.
Old Sep 17, 2015 | 09:06 PM
Tom57's Avatar
Tom57
The radiator should not move. The hoses that connect the radiator to the engine provide all of the play that might be needed. The transmission fluid cooler lines that run from the trans to the radiator are solid stainless steel. No wiggle.
Old Sep 18, 2015 | 08:45 AM
Bocatrip's Avatar
Bocatrip
Thank you Tom57 for your feedback. Actually, I checked this morning and the transmission cooler lines that run directly into the radiator are rubber. They might have been cut at one time to accomodate the radiator which is a Denso aftermarket. I've ordered an upper radiator support bracket to see if it makes any difference since it is made out of rubber witch presently is 14 years old.($15 for bracket) If not, providing a very slight bend to this bracket should tighten up the very slight gap, which as mentioned earlier is minimum once the car warms up and expansion takes place.
Old Sep 18, 2015 | 08:55 AM
Tom57's Avatar
Tom57
Smart Boca. It's probably the upper support bracket. You definitely don't want the radiator to shake -- over time, it could cause premature radiator failure.
And you are correct, there are short rubber hoses that connect the stainless steel trans lines. Again, these insulate the engine vibration and allow for slight movement of the engine and transmission. However, the radiator should not be free to move around.
Old Sep 18, 2015 | 09:06 AM
Bocatrip's Avatar
Bocatrip
On my way to Lexus to pickup upper support bracket, engine air filter, and a few clips. To be continued .
Old Sep 18, 2015 | 10:07 AM
Fixman's Avatar
Fixman
Correct me if I am wrong. But ther is a ruber mont at the boot me as will that looks like a donut or a big o-ring.
If so I will do that as will.
14 years is a lot of time for ruber.
Edit: part number (SUPPORT, RADIATOR, LOWER 16535-74030)
Old Sep 18, 2015 | 11:14 AM
Bocatrip's Avatar
Bocatrip
Installed one new upper support mount and PROBLEM SOLVED! Tight as a drum!!!!!.. Just ordered another one to play it safe for the other side although I really don't need it. The part number for those who are interested is 16505-50090 upper radiator support. When I placed the 14 year old support next to the fresh new support it was like night and day. The rubber was supple and extended out a considerable amount to make contract with the top of the radiator. The old one was hard as a rock with no movement and depressed in as not to make any contact. Thank god this was an easy fix! Thanks Tom57 and all the others for your help.
Old Sep 18, 2015 | 11:26 AM
Tom57's Avatar
Tom57
Great DIY fix Boca. For anyone replacing their radiator, the upper radiator supports should be examined for rubber deterioration. You were smart to check your radiator after dealer install. Trust but verify.
Old Sep 18, 2015 | 01:49 PM
Bocatrip's Avatar
Bocatrip
Thanks Tom. I have historically always gone over work that is done by a dealership or an independent regardless of how trustworthy they may be. Mistakes are made and consistent quality work is hard to find. Besides, I'm an over the top perfectionist and hard to please. I do the exact same thing whenever my girlfriend's Infiniti goes in for service. When I finally sold my 04 G35 Coupe after 10.5 years of ownership, the new owner literally got a like new car. Although my LS430 is 14 years old, whatever needs attention gets done right away. That is why absolutely everything on my car works and works well, and all important maintenance items are taken care of regularly.
Old Jul 25, 2019 | 08:01 AM
StanVanDam's Avatar
StanVanDam
Just checked mine, no play in my radiator so far, car in-service 17 years now, with 167,000kms, so relatively low annual mileage + minimal summer driving. This is a quick and easy item to add to a regular maintenance checkup.
High mileage over lots of bumps/potholes, combined high temperature climates, would likely accelerate the aging of these upper supports and require more frequent checks.
Old Mar 24, 2024 | 12:09 PM
buddhi's Avatar
buddhi
Default No coolant
Sitting now by side of road waiting for a tow. Smelt burning on highway, thought it might be outside. Drove another 10 miles at speed and turned off highway. Drove another 5 miles. Then smelt more like wires burning- previous was like brakes. Then noticed temperature pegged to red. Stopped. No coolant, bottom hose off. Engine and radiator both cool. Had a timing belt etc changed yesterday. Isn’t the engine supposed to stop when it starts to overheat? Ran fine the entire time. With no coolant.
Old Mar 25, 2024 | 11:05 AM
Bocatrip's Avatar
Bocatrip
Hopefully you have no engine damage....If there are any serious issues, it would be advisable to head back to the timing belt tech as there is where your problem most likely originated.
Old Mar 25, 2024 | 12:26 PM
buddhi's Avatar
buddhi
Got towed to the garage that did the timing belt and dropped it off.
Now it's the day after the disaster. Spent the night looking at used engines online and fuming. No doubt they forgot the clamp. Why would you replace the
hose without the clamp, since you need to slide on the clamp first? If the clamp were not tightened, you'd think the clamp would still be on the hose end,
but maybe not.
Got a called a short while ago, said all is fine. Compression test, another test (not the leak-down test, which was not needed), with test drive found all is well - and no codes.
Seems impossible.
When I stopped beside the road and looked, the coolant hose was off, no coolant at all, which would have dumped instantly.
No coolant under the car where I stopped, no CEL, no warning lights, and no trail of coolant on the road, both engine and radiator felt cold (not just cool) when I looked under the hood.
Coolant pooled at bottom of engine bay. I read this 4.3 engine has no coolant warning system. Apparently, it doesn't need one because it drives fine without coolant, so no radiator is needed either.
This is a true miracle. I will write the Vatican to get certification - can you be a Saint and not know it? Heck, I don't even go to church.
Just made some coffee and am ready to redo that same highway speed run. Will look for my missing coolant along the way.
IS_Sunny
Jun 24, 2015 08:51 AM
Measured
Jul 14, 2013 10:45 PM
Och
Sep 22, 2011 10:27 AM
SC300_704
Feb 28, 2010 02:11 PM
dung0981
Performance
16
Jan 26, 2007 05:51 AM
