Transmission fluid question
So I know trans fluid flushes are generally frowned upon with the ws transmissions, but I picked up this 2004 with 170k on it with what I'm assuming is original fluid. Pours like water, smells burnt, etc. I've got 13 quarts of WS sitting in the garage. So my question is should I do 4 or so drain and fills each maybe a few weeks apart or buy a few more quarts and get someone to flush it for me?
I guess I'm getting my terminology wrong but that is what I was referring to as a drain and fill.
well you'll get plenty of opinions on this but thats all they are. I've heard very little if any hard engineering data on the subject.
if it were me in your situation, I'd do the drain and fill as many times as it took for the fluid to come out reasonably red. Probably 500 or so miles apart. With that approach you get very close to the same end point, with lower risk. by the way, if you go that route, tilt the front of the car up and then drain...that tactic is getting me another half qt in the drain, as opposed to draining from a flat car. Move the shifter through the gears too...that seems to shake loose additional fluid too.
yeah the age of your fluid does give one pause. I'm going through this with fluid that is 65k old, and while not burnt or watery, there was little to no hint of red in it. Not acceptable to me at all. I've done two drain and fills, am quite curious to see what i get in the third drain. I've been taking pictures and will post up when the series is done.
As your car a 2004 it's the 6 speed trans. The fluid is not read. The filling proceder as I remember requires to fill till oil idle coming out of the full plug. Then start the engine to bring the oil to a certain temp then fill from the full plug. And repeat 4,5 times till oil come out of the full plug. That is why I suggested to search it 1st.
It's not like the old transitions wher you drain, fit new filter, and fill from dipstick. Drive for few miles and recheck the dipstick and add as needed.
All I am trying to do is give you advise on what I have learned from other members.
The call is yours.
Wish you all the best.
The call is yours.
Everything you possibly could need to know is in this fantastic thread:
https://www.clublexus.com/forums/ls-...er-thread.html
It's a heated debate, but I know many transmission builders that will tell you if it's at 170k on the original fluid, you could be opening up Pandora's box by changing the fluid, even with just "drain and fills".
I would ask around some transmission shops and get some input.
I think the ideal would be to change the fluid in a timely manner, but I do think once you reach a certain point it becomes a gamble as fresh fluid has a lot of detergents that can pull out varnish and deposits. Other people here will have different thoughts on it but I think you should know both sides.
Let us know how it works out for you.
Guys, I own an LS430 2006 model year and when it had over 100K miles I started researching about replacing/completely flushing the transmission fluid. I came across multiple posts in favor of it and against it. Then, I finally spoke with an engineer (materials science) who said, there is no oil that has ever known to last forever. All oils have life and viscosity that wears off with time and friction. So, I took it to a private shop and they very easily hooked it up to the oil replenishing machine and poured 13 Qts of fresh WS oil (right in front of me); and started the car. The whole process took less than 10 minutes and much to my surprise, the old oil was like black dirty water like material. And the mechanic told me that I came at the right time, and hopefully no damage was done to the trany. So, my advice to the wise guys is that "please go ahead and take it to any private shop who has this machine; and most of them do. It cost me only $175.00. The process is very easy. First they took the plastic shield from under the car; then they exposed the two transmission hoses; detached them and hooked the machine. The rest is machines' job. I actually wasted months exploring and ran into much controversial stupid and unnecessary debates and posts. Ask any engineer and use your own brain. Nothing lasts forever! So, replaced it if you have over 60K miles asap. I hope that helps. if you are confused on any of this,, contact me and I can further guide you.
Don't worry about you model year; just get a complete transmission flush. I know some 2001 thru 2003 have drain and fill capability. If so, go ahead and drain and fill the same amount you took out. At least half is fresh.
Are there any issues with doing the full flush with 13 quarts? I thought people said it was better to do multiple drain and refills of like 3 quarts. I have 144k and am due for service soon, and it's never been changed in my 04... Ive been thinking about it.
