Custom LED High Mount Third Brake Light Module
Old Dec 11, 2017 | 02:45 PM
  #46
lsdude's Avatar
lsdude
I recently bought one. Overall, I'm happy with the upgrade. But once the diffuser is installed, it doesn't make all the LEDs uniform (if that makes sense). If I look straight from the back, a few of the bottom LEDs are dimmer (due to the patterns on the diffuser). Does anyone else have this issue? My LS430 is an 06.
Old Dec 11, 2017 | 03:15 PM
  #47
Mobius1's Avatar
Mobius1
So i just came across this mod today. My only question is, does it error out the self-check and require in line resistor? Because i have tried single-bulb LED solutions for the 3rd brake light and it errors out with a Red Triangle icon thinking that its burned out.
If this doesn't fail the self-check i may have to look into getting one myself.
Old Dec 12, 2017 | 11:36 AM
  #48
2KHarrier's Avatar
2KHarrier
I was wondering the same thing, but saw no mention in the thread of LED lamp problems like we see with the tail lamps, so perhaps it was built with the resistor in place..
Old Dec 12, 2017 | 01:54 PM
  #49
Tom57's Avatar
Tom57
I'm the OP. No in-line resistor needed. No circuit failure warning on dash. Plug 'n play install.
Old Dec 12, 2017 | 01:56 PM
  #50
Tom57's Avatar
Tom57
I don't have this issue on my '06. It looks OE on mine.
Old Dec 12, 2017 | 03:51 PM
  #51
lsdude's Avatar
lsdude
Tom57, did you put the LED light loosely in the casing and use the diffuser to hold it in place? That's how mine is installed.
Old Dec 12, 2017 | 04:40 PM
  #52
Tom57's Avatar
Tom57
It's been a couple years, but I believe I placed the diffuser in front of the LED panel. I remember the perimeter of the light panel just fit inside the light housing. I adjusted the panel to get it perfectly horizontal in the light assembly. I may have used a small strip of tape to hold it in place.
Old Dec 18, 2017 | 10:57 AM
  #53
Mobius1's Avatar
Mobius1
Looks like this mod works best with 04-06 possibly. I just got mine in the mail today and installed it into my 2003 LS 430. Starts up without a warning but chimes a Tailamp Failure and red-triangle as soon as i hit the brakes. My search continues...
Old Dec 18, 2017 | 07:39 PM
  #54
lsdude's Avatar
lsdude
Have you tried to contact the seller? Since he built them, he may have an idea of why you're getting the tail lamp failure.
Old Dec 19, 2017 | 10:15 AM
  #55
Mobius1's Avatar
Mobius1
I'll contact them to see if they have any ideas. But i don't see much recourse. Plain and simple the circuit isn't seeing the correct voltage or something and throwing a failure warning.
Old Dec 19, 2017 | 11:41 AM
  #56
05ls430518's Avatar
05ls430518
You would probably have to wire in a resistor to make it work man.
bgrant7
Nov 23, 2017 12:56 PM
Aristo722
May 13, 2016 02:10 AM
miniz
Oct 17, 2012 07:41 PM
dejafa
RX - 1st Gen (1999-2003)
12
Nov 4, 2008 03:05 PM
rgarjr
Apr 16, 2004 08:33 AM
