2001 LS430 Trunk problem
Old Apr 5, 2015 | 10:52 AM
bossrek's Avatar
bossrek
Exclamation 2001 LS430 Trunk problem
Hi guys I bought 2001 LS430 done 158 miles and seems good working conditions
i have two issues i hope some one can help
Trunk release working good but remote control button does not respond i tried to use the lock under the driver knee but no any hope
can any body find a solution or is there a fuse that control the opening trunk
Navigation is working but the maps seem old how i can update the maps which version i can buy
wondering if any of you guys had similar problems
Thanks
Old Apr 5, 2015 | 12:02 PM
KING's Avatar
KING
CL Folding 25,000
Congrats on the purchase.
Have you tried different keys?
I'm assuming the remote locks/unlocks the car?
You might have a faulty locking/unlocking sensor in the back. That sensors needs to feel you're close to it so that it can process opening the trunk. It's located in the right behind the rear bumper cover.
Old Apr 5, 2015 | 12:22 PM
bossrek's Avatar
bossrek
Thank you for your reply
I tried other buttons it does lock and unlock the doors and if you keep holding the unlock it will open all the windows and the sun roof too
and for the trunk actuator it works fine also i can find a small micro switch behind the bumper it is working
i think it is fuse issue but i dont know where and which one is it
Old Apr 5, 2015 | 12:30 PM
bossrek's Avatar
bossrek
you mean this sensor pls check the pic below
Old Apr 5, 2015 | 02:03 PM
mscheidm's Avatar
mscheidm
Default Hold for 2 seconds
Not sure if you know, but I thought I had the same problem when I bought my first Lexus (ES 300). Try holding down the trunk button on the remote for 2 seconds.
Old Apr 5, 2015 | 02:07 PM
bossrek's Avatar
bossrek
that was my first attempt
Old Apr 5, 2015 | 04:47 PM
Lavrishevo's Avatar
Lavrishevo
Is the valet trunk lock on? Make sure it is off. If not, I would then look at the key itself.
Old Apr 5, 2015 | 04:54 PM
bossrek's Avatar
bossrek
Hi
Can you please explain how to turn it on or off ?
if you mean the lock near the release button located driver knee side , I already checked it
and it is working when i activated the release button stop working
Old Apr 5, 2015 | 05:14 PM
Lavrishevo's Avatar
Lavrishevo
Put the key in, turn, and make sure it is not engaged. Pushed in is on. You want it off.
Old Apr 5, 2015 | 05:39 PM
bossrek's Avatar
bossrek
yes i did it and it is functioning when it is not engaged the release button does not work and when it is not
the release button works
i have no problem at all with the driver side button my only concern is the remote control
Old Apr 5, 2015 | 06:34 PM
Lavrishevo's Avatar
Lavrishevo
I would look at the key fob next.
Old Apr 5, 2015 | 07:43 PM
bossrek's Avatar
bossrek
so you mean my key fob is the problem
is there any fuse i can check ?
Old Apr 6, 2015 | 03:16 PM
zapola6's Avatar
zapola6
You can test your Key FOB at most AutoZone Stores...
It's not a simple press the button on the key and the trunk will open like the doors, you have to hold the trunk button down for a few seconds....
Had the same issue when I got my LS, took me a few days to figure it out..
Old Apr 7, 2015 | 05:58 PM
bossrek's Avatar
bossrek
Default key fob
hi
I have done this test and all of the buttons looks active
please check my key
Old Apr 7, 2015 | 06:40 PM
Tom57's Avatar
Tom57
hi
please check my key
Your key does not look at all like a genuine 2001 LS key. That is likely your problem. Note the "Lock" and "Panic" button on the genuine LS key is the same button. The trunk release button is separate. Start with the correct key. These '01 - '03 keys are DIY self-programmable too (as long as there are remaining key "open slots" available on the onboard computer). See https://www.clublexus.com/forums/ls4...ansponder.html
