Standard Disk or Low Disk in the rears? Without Spacers
Old Nov 10, 2014 | 02:43 AM
vipmikey's Avatar
vipmikey
Default Standard Disk or Low Disk in the rears? Without Spacers
Hey guys I'm planning on purchasing new wheels soon from Works but I was wondering what would be a better route because I'm not sure on clearance in the rears? Would I be able to push low disks in the rear (for more lip) without spacers or would I have to run standards? Thanks in advance!
Old Nov 11, 2014 | 01:26 AM
vipmikey's Avatar
vipmikey
Anyone? =O
Old Nov 11, 2014 | 06:47 PM
daniel1235's Avatar
daniel1235
Ho brah howzhit. U stay use da serch ki? It da kine help fine stuf.
Heres a start.
https://www.clublexus.com/forums/ls4...nce-guide.html
Old Nov 11, 2014 | 09:07 PM
vipmikey's Avatar
vipmikey
Heres a start.
I checked that already. Only says hi disk for fronts cause of the bbk. I'm trying to figure it out in the rears if I can push super low disk basically.
Old Nov 12, 2014 | 12:52 PM
daniel1235's Avatar
daniel1235
Yes you can push super low disk on the rear more than likely. Your offset and rim design will be a factor as well.
Old Nov 12, 2014 | 01:44 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
yea low disk is not a problem in the rear, fronts you can experiment with possibly a mid disk.
Old Nov 12, 2014 | 04:27 PM
vipmikey's Avatar
vipmikey
Yeah I don't have many options when it comes to experimenting with any wheels. Going to buy a brand new set of works so I'm trying to order it right the first time and save myself the headaches!! Thanks though. Nice 430 btw, see it on instagram a lot!
Old Nov 12, 2014 | 04:30 PM
vipmikey's Avatar
vipmikey
Thanks for the input. Now the offset is starting to make me wonder -__-"
Old Nov 12, 2014 | 04:33 PM
HiloDB1's Avatar
HiloDB1
I run Hi disk front, super low disk rear. Shouldnt be a problem as long as width/offsets will work.
Old Nov 12, 2014 | 04:39 PM
vipmikey's Avatar
vipmikey
When you say "as long as width/offsets will work" do you mean as long as the wheels are in spec to fit under the fenders without body work? Cause I'm planning on going pretty aggressive with camber haha
Old Nov 12, 2014 | 04:45 PM
HiloDB1's Avatar
HiloDB1
Yes assuming you clear fender/body and any suspension linkages/shocks
Old Nov 12, 2014 | 05:56 PM
vipmikey's Avatar
vipmikey
Thumbs up
Thanks for the help!
Old Nov 13, 2014 | 06:30 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
thanks man, see if u can find someone local to you that has a set of wheels that are mid disk.
ct200
IS F (2008-2014)
Jun 23, 2014 04:01 PM
lkapimp216
Mar 22, 2011 03:11 AM
nGeee
Feb 9, 2011 12:44 AM
Pearl250
May 6, 2010 07:45 PM
Curry
Wheels, Tires & Brakes Forum
Nov 5, 2007 06:44 PM
