Air suspension replacement instructions
Old Apr 13, 2019 | 09:59 AM
  #31
ChenSiew's Avatar
ChenSiew
Default Rear air suspension replacement
Originally Posted by Gene01
You must remove the fuse for the compressor if you raise the car with the wheels off the ground.
In my opinion, you will be much safer to disconnect the battery.
i have just replaced my 2007 Lexus LS460 rear air suspension both sides. But after installation, while the air pump started to working the car back to normal height, only right hand side (front and back) is lifting up and the left side (front and back) continued to stay low.
I did not remove the battery prior to installation.
I am not sure if there is a sensor need to be reset or simply the new rear suspension on the left side that I just installed is malfunction and therefore the air cannot flow to the left side..
Jeremyaudr
GX - 1st Gen (2003-2009)
Oct 1, 2018 12:51 PM
Bennyd2420
Jul 19, 2016 12:28 AM
Chemtj
Nov 10, 2014 06:48 AM
Tatty93LS
12
Oct 2, 2013 12:07 PM
xtrmnop
Nov 1, 2009 06:12 PM
