06 LS: stumbling and rough part throttle acceleration
Old Jan 25, 2014 | 08:51 PM
jcp's Avatar
jcp
Default 06 LS: stumbling and rough part throttle acceleration
Hey guys,
I am experiencing roughness when under light and part throttle acceleration. It is most noticeable when going uphill and feels like my car almost stumbles when accelerating lightly. However, when I accelerate anything more than half to full throttle acceleration is smooth and strong with no roughness or stumbling.
My car has 65k miles. Any thoughts what the problem is?
Thanks
Old Jan 26, 2014 | 05:50 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
you might try cleaning your throttle body and then disconnecting your battery to reset you ecu.
does it seam to be your engine or transmission?,happen every time.
any more information my help.
Old Jan 26, 2014 | 08:23 AM
Lavrishevo's Avatar
Lavrishevo
No check engine light? Throttle body and dirty maf are good places to start looking.
Old Jan 26, 2014 | 05:12 PM
jcp's Avatar
jcp
I've reset the ECU with no luck. It definitely is the engine that is running rough, not the transmission.
I notice it primarily when the car is in higher gears at low engine speeds under load. Easiest to notice when going up a grade putting a load on the engine. never notice it going downhill.
No check engine light ever. I will do a search on cleaning MAF and throttle body.
Thanks fellas!
Old Jan 29, 2014 | 08:30 AM
ls430lover's Avatar
ls430lover
first thing i would do go to walmart buy the chevron fuel system cleaner, not the fuel injection one, then on empty tank or 3.4 empty pour bottle in , fill with shell premium gas and respond to me in couple days saying problem solved, all kidding aside 40% of time this will work with a clogged injector
Old Feb 15, 2014 | 03:52 PM
jcp's Avatar
jcp
Did the following and still have the low rpm stumbling:
1. Used several bottles of fuel injector cleaner at the last couple of fuel ups
2. Cleaned the MAF w/ CRC MAF cleaner
3. Cleaned the throttle body w/ CRC throttle body cleaner
4. Disconnected battery to reset ECU
Any other ideas to eliminate the stumbling? As mentioned previously, I notice it mostly when in top gear around 45mph under part throttle going up a grade.
Thanks
Old Feb 15, 2014 | 11:09 PM
Lust4Lexus's Avatar
Lust4Lexus
MAF could actually be shot. Maybe get the FI's professionally cleaned?
Old Feb 16, 2014 | 02:11 PM
username32's Avatar
username32
Could be a bad TPS (which is not good cause i think its integral part with TB assy) or a slow responding 02 sensor. Hopefully its not a VVTi solenoids or anything. Id plug it into a obdII scanner and see the readings while you drive to see whats happening. Id point to the MAF as well, and when cleaning them make sure you are cleaning all the way inside the tube because the element is actually way towards the back hard to spray spot. Make also certain there is no debris or dirt on the element. A single tiny piece of dirt can cause all sorts of false readings.
Old Feb 16, 2014 | 02:32 PM
username32's Avatar
username32
As far as fuel system cleaners go, from past experiences with virtually all major cleaners on the market only 2 left me rather impressed that it actually does something. the BG44K and the Redline SI1 Fuel System cleaner.
Moarpower
Mar 31, 2018 09:12 PM
AlaskanLS
26
Feb 27, 2017 02:52 PM
Mcon
Feb 14, 2015 02:14 PM
LSPiNoY
Oct 14, 2004 12:00 PM
TRULUX
Sep 1, 2004 08:53 PM
