Unusual problem
Old Dec 18, 2013 | 07:58 PM
stewbertso's Avatar
stewbertso
Default Unusual problem
I recently put some ASA rims with Blizzak tires on my 2004 LS430. Several days after putting them on I heard strange sounds from the front driver side wheel. Went to my local Lexus dealer and they found only two lug nuts on the front driver side wheel. The other 3 lug nuts were gone and one of the lug nut studs was broken off. How could this have happened? I put the rims on myself and tightened them with a torque wrench.
Also how hard is it to replace the lug nut studs? Is this something I can do myself? Thanks!
Old Dec 18, 2013 | 08:19 PM
Stu's Avatar
Stu
very strange. Just wondering if the dealer did a service requiring them to remove the wheels.
If you torqued the wheels on properly, the 3 missing lug nuts and the broken stud must have been done at the dealership ... these are not things that fall off and break easily at all. Must be a sloppy Lexus dealership to return your car to you in an unsafe condition. I would speak to the manager.
Unless you have special tools, I don't think you'll be able to repair the lug stud yourself. Pretty sure it needs to be drilled and extracted - something I would not personally try to do.
Old Dec 19, 2013 | 07:17 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
prob overtightened and snapped off.
replacing the studs are easy, youtube some videos and there are plenty of DIYs.
Old Dec 19, 2013 | 07:51 AM
silos5's Avatar
silos5
maybe some hater wanted to get your wheels ??
similar happened to my boss´s car, where someone wanted to steal wheels or just do some harm, so the nuts were loosen and the wheel flew away...noone hurt !
Old Dec 19, 2013 | 11:48 AM
ancdmd's Avatar
ancdmd
Did you use the correct lug nuts for those rims? I believe there are a few different seat/mating surface designs for the nuts: round, flat and conical. If you used the wrong ones then even if you torqued them I can see them loosening fairly easily. I am not sure what the stock lug nuts are but I know the lugs for my aftermarket wheels are different than the stock ones.
Old Dec 19, 2013 | 06:12 PM
UZ214's Avatar
UZ214
the nuts become little lose, over 500 mile period- you are suppose to revisit and double check if everything is secure. My wifes friend RX350 had her wheel almost come off after 4 months of a brake job.
Richardgil
Jan 21, 2019 12:33 PM
GrubLife
Suspension and Brakes
Mar 30, 2018 09:36 AM
OG Dada
Aug 14, 2012 04:33 PM
ashtray
Wheels, Tires & Brakes Forum
Aug 7, 2012 10:27 AM
tgara
Jun 23, 2009 11:10 AM
