Lug Nuts loosen themselves
Old Mar 26, 2018 | 11:02 AM
GrubLife's Avatar
GrubLife
Default Lug Nuts loosen themselves
So i took off my rims, and put on the stock 17" Lexus Alloy, torqued down the lugs and drove off. within 30 seconds, my wheels were making all types of crazy knocking noises. i got out to inspect and the lug nuts were loose. i lifted her up, tightened again, then dropped her. Then torqued again. drove it back into my driveway (30 seconds at 1mph) and they were loose again. Opened it up, no sliding, both lug and stem aren't stripped.
Anyone ever had a ghost try to jack your rims while driving?
Old Mar 26, 2018 | 11:12 AM
captainva's Avatar
captainva
To me that sounds like the wheel might not have been seated on the hub properly. I would take the wheel off and make sure that its properly centered on the hub then re-torque the lugs. If its off to one side it can clunk like that
Old Mar 26, 2018 | 11:26 AM
GrubLife's Avatar
GrubLife
its super weird. it wasnt just clunking, it was loosening the lugs. i cleaned the back of the rim, and the hub surface, to make sure there's no dust bumps. and with star formation i added each lug, and check to make sure the wheel and base were flush. then tightened, dropped and torqued. and it happened again!!! LOL Im telling you this car is haunted!
Old Mar 26, 2018 | 01:24 PM
captainva's Avatar
captainva
Has this happened before or is this a new set of aftermarket wheels?
Old Mar 26, 2018 | 02:06 PM
GrubLife's Avatar
GrubLife
I think i may have figured it out. This is only happening with the stock GS rims. i believe the stock GS rims can only use stock Lexus lug nuts because it has that stopper. but since i have extended studs, i was using the aftermarket lugs. i think the rims is forcing the aftermarket lugs out via pressure and its turning the lugs within the groove. i might need to find some open ended lexus lug nuts that have that stock plate. so it can secure and still clear the extended studs
Old Mar 26, 2018 | 02:29 PM
captainva's Avatar
captainva
Sounds like you found your culprit. Toyota has unique lug nuts and aftermarket lugs don't work well on factory wheels in my expeirence
Old Mar 27, 2018 | 10:08 PM
lexo98's Avatar
lexo98
For your wheels you need the oe toyota style shank lugnuts. might be hard to find but there are some aftermarket lugnuts that are open on the ends so your extended wheel studs can stick out. There are also ones that are longer to accommodate a longer wheel stud but not sure if they will work for you
Old Mar 30, 2018 | 08:58 AM
newgsman's Avatar
newgsman
The lug nuts from a MKIII ('87-'92) Supra lug nuts had longer shanks and they also have the common Toyota/Lexus flat washer seating arrangement. The other option is to reinstall the stock size studs
Old Mar 30, 2018 | 09:30 AM
Superman60's Avatar
Superman60
Glad you found it, I was going to say sounds like you have the wrong lug nuts on it.
Old Mar 30, 2018 | 09:36 AM
GrubLife's Avatar
GrubLife
Yeah it was sooooo weird. ive never experienced a lug nut loosening itself. i was perplexed. Had to think of it scientifically to try and figure out how it would do that. LOL
bigblack06
Feb 8, 2014 04:13 PM
OG Dada
Aug 14, 2012 04:33 PM
ashtray
Wheels, Tires & Brakes Forum
Aug 7, 2012 10:27 AM
mgtype
Feb 6, 2009 03:30 PM
