Still having brake issues
2002LS430. Brake pedal has excessive travel before brakes will engage. Probably 2-3 inches. Pedal is soft and mushy. Stopping power decreased. Any thoughts greatly appreciated. I had it in to the Toyota dealer recently and they replaced the master cylinder but that didn't help. Is a soft, mushy pedal normal? Any ideas greatly appreciated before I take it back in.
Thanks,
Harry
Thanks,
Harry
No, it is not normal. Since you already replaced the MC take a look at the brake piston seals and your hoses. They can deteriorate from the inside and cause excessive travel and mushy feel. Even if it is not leaking. Did you have the whole system flushed? Should be done every 90k. Also, did they bleed the air out properly?
It is most definitely NOT normal, but it IS dangerous.
Was it mushy when you got it back, or did it start some time later?
These are typical symptoms of air in the brake system. If you trust the last shop who serviced it, take it back to them and complain loudly. There is no excuse for them leaving the system in that condition.
Still having the same trouble with brakes as I reported before. Soft mushy pedal, excessive pedal travel before brake engages, sometimes 2-3 inches of travel. So I took it back to the Toyota dealer today. They "took the brakes apart" and thoroughly checked all components including the booster and master cylinder. Found no trouble. I'm beginning to think its just me . Drove my wife's Honda over the holidays and that pedal is hard as a rock and engages immediately with light pressure. Same on my old Ford Ranger , pedal is hard and engages immediately. I looked at Lynzoids posts and asked them to check seals and hoses which they did but still say everything is OK. They did not bleed the system . Could it be air? Or is it just me that I want a hard pedal?
Thanks for ANY input as I am almost ready to give up but really can't because it may be a safety issue.
Agree - LS430 brakes even with all new pads is not rock hard. Go drive another LS and see if yours is different. In the end you need to be able to lock up the brakes to the point where ABS takes over and also be able to make quick stops just short of ABS kicking on.
And now for some wild guessing - use stock OEM pads? Assuming no leaks, as previously suggested old brake hoses might be a factor. OEM rotors? are they within spec for thickness? Proper brake fluid type used?
Thanks,
Harry
Thanks,
Harry
TechyInAZ
RX - 1st Gen (1999-2003)
Jan 2, 2019 04:44 PM
en11871
Apr 17, 2010 05:32 PM
Bane
Jun 13, 2005 01:06 PM
