Will this wheel fit ?
Old Nov 20, 2013 | 12:52 PM
shangsterh's Avatar
shangsterh
Default Will this wheel fit ?
Just wondering if anyone has this set up:
18x9 + 35, 5x114.3
with
255/45/18
I feel like this might rub... any thoughts?
Old Nov 20, 2013 | 03:32 PM
HiloDB1's Avatar
HiloDB1
You should be fine. Thats not an aggressive fitment. Is your car lowered?
Old Nov 20, 2013 | 04:53 PM
RA40's Avatar
RA40
Super Moderator
Welcome to Club Lexus.
That is a pretty conservative fitment and should not pose any rubbing issues.
Old Nov 24, 2013 | 07:32 PM
shangsterh's Avatar
shangsterh
No, its stock, but i feel like the 9inch wide with 35mm offset might be close to the calipers?
Old Nov 24, 2013 | 08:15 PM
Lavrishevo's Avatar
Lavrishevo
Just going to have to test fit. If the fronts rubs a little a 10 or 15 mm hub centric spacer will fix that.
Old Nov 24, 2013 | 09:46 PM
shangsterh's Avatar
shangsterh
are you refering tohub centric ring or wheel spacers?
i dont want really want spacers, thats why i'lm asking if anyone had this set up.
Old Nov 24, 2013 | 09:49 PM
shangsterh's Avatar
shangsterh
Thanks!
From the wheel offset calculator http://www.1010tires.com/Tools/Wheel...ulator#Results
i get Results
Inner Clearance: 9mm LESS (the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 29mm (position of the outside edge of the wheel)
I think the offset is a bit low, what do you guys think?
Old Nov 25, 2013 | 02:33 PM
SQuester's Avatar
SQuester
Rim width and offset have nothing to do with possible caliper clearance issues, that's what's called disk height.
You'll have to test fit them to be sure unless you know the rims are a high disk type.
Old Nov 26, 2013 | 01:49 AM
ultm8mind's Avatar
ultm8mind
I don't see an issue with that, I have 20x9.5/10.5 set up and stock height they don't rub.
Old Nov 26, 2013 | 06:47 AM
Lavrishevo's Avatar
Lavrishevo
+1 19's on up are rarely an issue. 18's on the other had can be.
Old Nov 26, 2013 | 09:47 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
I probably would go with 245's or even 235's up front. 255's might rub.
Other than that as long as they clear the brakes you should be alright.
wcoyoy23
Jun 4, 2017 08:25 AM
qboy3388
May 18, 2017 12:54 PM
eljodemuch
Jan 23, 2017 09:39 AM
BlackISFtx
IS F (2008-2014)
20
Jan 30, 2015 10:05 AM
Noypi
RX - 1st Gen (1999-2003)
Oct 4, 2007 09:45 PM
