Another repair FAIL
Old Aug 23, 2013 | 02:39 PM
ancdmd's Avatar
ancdmd
Default Another repair FAIL
I went to GarageYourself here in Miami to diagnose a loud clunking noise in my front suspension and found a sway bar end link completely separated from the bushing and the bar end. The Toyota dealer mechanic had installed the links two years ago. The link on the passenger side was installed on the inside of the bar end flange and not on the outside. To make matters worse he didn't even use the washer to prevent the link from separating from the bushing. On top of that, since then I've had at least two other dealers and a couple independent shops check the front end because it just didn't feel right and nobody ever noticed the improperly installed link. Very reassuring. Typical South Florida crap.
Attached Thumbnails Another repair FAIL-image-978219332.jpg   Another repair FAIL-image-1001215173.jpg
Old Aug 23, 2013 | 03:03 PM
jayclapp's Avatar
jayclapp
This is one reason why I never let anyone other than my Lexus dealer service and work on my car.
Old Aug 23, 2013 | 03:49 PM
DonMolina's Avatar
DonMolina
Renowned BMW dealer in Athens, Greece, changed my pads in my 7er once and didn't put the pins correctly. Pads was basically hold because of too much wear in the disc, that created a dish the pad could nest in...
Indy replaced the radiator in the LS right before I drove up to Switzerland. Didn't bleed the system properly. 2.5k Km later, and 3 days before the inspection to take my new plates, the car overheats as I get in my garage. I bleed it properly and everything fine, crisis averted.
Dealer, or no dealer, if a mechanic is an idiot he can majorly screw your car. Problem is that if you don't notice on the spot or upon receival of the car, there is very little you can do apart from never going to that place ever again...
Old Aug 23, 2013 | 04:22 PM
RA40's Avatar
RA40
Super Moderator
The mechanic finished the job and thought..."what's this spare washer for? Oh well I'm off, time to get some brew!"
Old Aug 23, 2013 | 06:00 PM
ancdmd's Avatar
ancdmd
The large washer was actually still there. it was on the OUTSIDE of the sway bar end flange, essentially doing nothing.
Old Aug 23, 2013 | 06:01 PM
ancdmd's Avatar
ancdmd
Surprisingly I've had the worst luck with the Lexus dealers. The best have been the independent techs.
Old Aug 26, 2013 | 04:24 PM
ancdmd's Avatar
ancdmd
Originally Posted by GSXMike
When it originally made noise you should have jacked the car up to inspect it, or take the car back to Lexus so they could address the issue. This way you could have eliminated any further problems not only with incompetent shops but any wrecks that could have occured.
That's part of the problem... I took it back a couple times and they say there's nothing wrong. Take it to other shops and I get the same BS. Living in a world of stupidity. If they can't do the job correctly the first time what makes you think they could do it correctly the second or third...
Old Aug 26, 2013 | 04:37 PM
Lavrishevo's Avatar
Lavrishevo
Yelp.com is a great website. I would just search it and look at the recommended shops. I do some stuff at the dealer and most everything else at a shop that I found that has great reviews.
Example:
http://www.yelp.com/biz/naulin-auto-service-miami
http://www.yelp.com/search?find_desc...&sortby=rating
Old Aug 26, 2013 | 05:55 PM
ancdmd's Avatar
ancdmd
Example:
Yes I do like Yelp, the most recent shop I've used is right near my place here in South Beach (Larry's) and they've got great reviews. They do have excellent customer service and don't charge me for small stuff but even they failed to find this issue. I will give them a little more slack because they are not Toyota/Lexus specialists though.
Chaitu
Sep 18, 2013 09:59 AM
Joey97
15
May 17, 2012 03:43 AM
Bumbobee
Dec 2, 2011 08:05 PM
witmaRX
RX - 1st Gen (1999-2003)
Aug 17, 2006 01:12 PM
GS430 GUY
Aug 1, 2002 02:20 AM
