Installing New HID headlight kit
Old Mar 9, 2012 | 06:50 PM
Djdan's Avatar
Djdan
Default Installing New HID headlight kit
I just bought a plug and play kit 6000k. I thought I would be able to install in my 03 LS430 in an hr or so but then I read somewhere that you need to take the front bumper off and the headlight casing in order to install. I have the ballast to install with the new bulb.
Any ideas or anyone have any experience installing HID kits?
Old Mar 9, 2012 | 09:35 PM
MEPEH's Avatar
MEPEH
Just remove the old bulb and plug in the HID Bulb.
Connect the bulb to the ballast and ballast to the plug that used to go on your stock bulb and you'll be fine
Should be plug and play
Old Mar 10, 2012 | 04:59 AM
Djdan's Avatar
Djdan
Default HID Kit
My problem is the ballast is going bad and I need to install the new ballast. If I install the new ballast I would need to disconnect the old ballast and I am not sure how to do that.
Old Mar 10, 2012 | 08:17 AM
MEPEH's Avatar
MEPEH
Are you replacing the stock HID with Stock ?
Or is that an aftermarket kit you want to put on the car ?
Old Mar 11, 2012 | 03:38 AM
j three's Avatar
j three
Go to http://www.theretrofitsource.com/index.php and hit them up about a replacement ballast for your car. You don't want to replace factory with after market.
Old Dec 11, 2012 | 07:53 PM
jctevere's Avatar
jctevere
Hey guys, I would like to know how the OP made out.
I have a benz, so I'm not familiar with this car. But my grandfather has a 2003 Lexus LS430. It had every single option, so I'm not sure if that matters or not.
His factory OEM HID's are giving him problems. One side will sometimes fail to ignite, but occasionally it will turn on, and then later turn off after a few minutes. I assume that the ballast is going bad...
He has NUMEROUS problems with the car and had the dealers replace both ballasts in the past. It just seems like the OEM stuff is junk. So I think I'm just going to retrofit an aftermarket HID kit to his vehicle since its cheap, and I can replace it 10x over if I need to.
Just some quick questions, what type of bulbs are the factory HID? I would assume D1S, however, the headlights are a reflector style housing and not projector lens.
Also, if I get a 5000k 35W kit, will I require error eliminators or relay harnesses? I'm not sure what the connection to the factory bulb looks like. But I'm hoping that I can just seat the aftermarket HID D1S bulb into the holder, drill a hole and fit a grommet into the dust cap to seal it.
But will I have to tap the battery for power, or can I just plug the ballast into the plug that goes to the factory bulb? Will the failing factory Ballast prevent that wire from giving enough "juice"?
Thanks for all the help!
EDIT:
Actually, now that I did some more thinking. It sounds like it could also possibly be just that the headlight bulbs are going bad. Maybe I'll just source some replacement HID bulbs and try those first to see if that works. I'm sure that he has never replaced the bulbs - most likely due for replacement. After a little bit more research, I believe that since it is a reflector housing the car should use D2R bulbs?
Old Dec 14, 2012 | 09:37 PM
xuserx04's Avatar
xuserx04
^^ I always thought that the dealer would change the whole headlight not the ballast in cases like yours.
Old Dec 15, 2012 | 08:34 PM
SBlexus's Avatar
SBlexus
EDIT:
Yes it sound like you have a bulb issue. Good luck
CCJ22
Lighting
Aug 13, 2011 12:40 PM
rclab1
Jan 23, 2009 07:56 PM
nytoy
Oct 12, 2007 01:45 AM
huerdo623
Lighting
18
Oct 8, 2007 12:37 PM
NAZTY97
Lighting
Jan 28, 2007 12:13 AM
