Door Check Replacement '01
Old 06-08-11, 01:25 PM
dflanigan
dflanigan's Avatar
Default Door Check Replacement '01
Has anyone ever replaced the door check(s) on an '01 430? I think it is called a door check. It's the "arm" midway between the upper and lower hinge that keeps the door from opening too far. Mine make a horrible clicking noise when opened or closed.
I saw some info on tightening a torx head bolt to stop the clicking but that was on an '02 and the description of the check area was definitely different than my '01.
Old 06-17-11, 12:41 PM
dflanigan
dflanigan's Avatar
Am I the only one with loud clicking door checks!!!!!!??????
Old 06-17-11, 12:52 PM
CarGuy89
CarGuy89's Avatar
Yes.....?. Have you tried putting some grease on it? Might allow the hinge to move about more freely.
Old 06-17-11, 12:59 PM
dflanigan
dflanigan's Avatar
Kind of, I sprayed it very well with 100% silicone spray.
Old 06-17-11, 01:29 PM
CarGuy89
CarGuy89's Avatar
Try something a bit more viscous, like vasoline. A physical layer of grease should be more effective I imagine. Sry to hear about the trunk btw. Wish I could help.
Old 06-18-11, 06:08 PM
dflanigan
dflanigan's Avatar
Thanks CarGuy89. I'll see if I can't get some grease way back where it goes into the door.
Did you hear I got the trunk opened? Yep, put a spare key in the key lock and turned it with a pliers, really hard. Lube it up and work it a couple times and it works great!!!
Old 06-19-11, 03:04 PM
CarGuy89
CarGuy89's Avatar
Originally Posted by dflanigan
...Did you hear I got the trunk opened? Yep, put a spare key in the key lock and turned it with a pliers, really hard. Lube it up and work it a couple times and it works great!!!
Yes I did, congrats!
Kennyr44
06-15-17 03:20 PM
Bix49
SC- 1st Gen (1992-2000)
14
07-11-13 12:15 PM
NemeGuero
02-20-10 10:43 AM
ZSC3
07-29-08 01:19 PM
Quick Reply: Door Check Replacement '01
