Help me identify 2006 LS 430 Model
Old Mar 17, 2011 | 07:43 PM
mrjazz's Avatar
mrjazz
Default Help me identify 2006 LS 430 Model
I just inherited a 2006 Lexus 430. 27000 miles. I had previously posted about a battery problem that the dealer traced to wiring from a 3rd party GPS locator.
Anyway, I want to know what model this is. I see no "Height Button" in front of gear shift, for air suspension, nor is there radio controls in the back seat. So that means it is not a UL model, right? I think I got misinformation from the dealer because service tech said all 2006 LS 430's were the same, and had air suspension. I believe this was wrong. Can you clarify?
The car has Mark Levinson sound, Navigation, power door locks, and rear seat heaters, I believe. What other info would the forum need to identify the model?
My stupid question is where the heck are the buttons to adjust the front headrests? I see the info in the manual, but don't know where to look.
Your help would be appreciated. This is a beautiful car.
Cheers
mrjazz
Old Mar 17, 2011 | 07:49 PM
Sentinel's Avatar
Sentinel
Its not a UL. Do you have head light washers? If not then you are not a CL... there is a post how to tell the differences..
https://www.clublexus.com/forums/ls4...ml-cl-etc.html
drpatel77's Avatar
drpatel77
the armrest in the middle of ur backseat... look at that .. if it has controls .. then it is UL... If UL then u have air ... If not then no... never used rear seat heaters so not sure about that...
got one myself a year ago but never have had time to play with all the buttons..haha... i am too much into my sc right now...
but crazy deal... 2006 c 27K miles... lucky bast**d... haha.. hope u like it.... it's so smooth ... if not pm me ... i know ppl who want an LS430 bad..
Old Mar 17, 2011 | 08:05 PM
CarGuy89's Avatar
CarGuy89
There aren't really any differences from 04-06. To answer the headrest question, it shares the same button used to adjust the back part of the seat. Simple pull up to raise the headrest and push down to lower.
Old Mar 17, 2011 | 08:10 PM
mrjazz's Avatar
mrjazz
I believe from what has been posted it is the Modern Luxury. No headlight washers.
Where's the headrest adjustment?
Cheers
mrjazz
Old Mar 17, 2011 | 11:03 PM
mrjazz's Avatar
mrjazz
I finally determined that it is a CL and not an ML. It does have headlight washers. I see the little windows on top of the bumper underneath the headlights. Also thanks for the help with the headrest adjustment. I found it.
Cheers
mrjazz
Old Mar 18, 2011 | 03:48 AM
AlexusAnja's Avatar
AlexusAnja
Make sure you have the headlamp washer button on the lower garnish of the center console. I've seen owners (or repair shops) put bogus CL bumpers on ML trims, so obviously no button for the washer....
Other ways to check for CL are leather surfaces on the lower part of dash (where glove box is) and center console surround, as well as laminated glass (roll down window and see if you can see two panes of glass laminated together.
You should be enjoying your 430 for a very long time.
David M
Lexus Vehicles Classifieds
Dec 16, 2015 09:53 AM
mrjazz
Feb 28, 2012 10:39 AM
spender
Mar 23, 2009 09:55 PM
djpeak10
Feb 24, 2009 12:54 PM
