Designed by Monkeys!!
Old Sep 12, 2010 | 01:15 PM
KaiserSea1's Avatar
KaiserSea1
Default Designed by Monkeys!!
Okay I love my LS but I have to vent. Changed the wiper blades today which takes 5 minutes on any other car For 20 bucks you get just the rubber, no box, and you have to reuse the metal bracket to slide it into the wiper blade. The bracket is two pieces that keep poping out while you try to slide the refill in. half hour job Come on for 20 you guys could not attach the tin guide.
Last DIY was the headlights on my SC. I had to drop the bumper.
Monkeys I tell you. Designed by monkeys!!!
Old Sep 12, 2010 | 02:20 PM
caddyowner's Avatar
caddyowner
It seems every modern car has a replaceable part that is so hard to replace that it seems the entire car was designed around it. For the Cadillac CTS / STS / SRX, it was the daytime running light. One had to remove the bumper or jack up the car, remove a front wheel, remove the inside fender liner, and hopefully have small enough hands to remove the socket. For the LS430, it seems to be the wiper blades.
Old Sep 12, 2010 | 04:27 PM
tcbted's Avatar
tcbted
Design by monkeys?
Ever try replacing the cabin air filter on a 98-94 Cadillac STS?
Located in the drivers footwell, virtually impossible to replace.
The concept of the filter was obviously thrown in after the interior was designed,
as an afterthought.
At the dealership, the senior tech's toss this job to the young monkeys.
Guaranteed to throw out your back and shoulder
Old Sep 12, 2010 | 05:19 PM
Kansas's Avatar
Kansas
I've found replacing wiper inserts on cars made by Toyota to be very easy and quick -- certainly less than five minutes per vehicle but I've had lots of practice including many years on several Mercedes sedans which used the same design on both windshield and headlight wipers. I don't even bother using the little plastic throwaway clamp that holds the metal ribs in place while I slide the rubber inserts into position. And I never bother to remove the wiper blades from the arms when replacing the inserts.
Are you reading the instructions? Did you have too many beers before tackling the job? LOL!
Old Sep 12, 2010 | 06:27 PM
jayclapp's Avatar
jayclapp
I remove the wiper blades from the arm (takes less than a minute). Then it's very easy to remove and insert the new blades. Don't try to do it when it's on the car.
Old Sep 12, 2010 | 07:27 PM
AlexusAnja's Avatar
AlexusAnja
Also, turn the wipers on and then turn key to off just as the wiper arm is in full up position. This will get you the clearance you'll need to pull the arm out.
I replaced the whole blade assembly with "triple edge" blades around the time I got the car and it's been fine since (almost 2 years).
Old Sep 13, 2010 | 06:33 AM
votru's Avatar
votru
I'm just replace the whole assembly as well and really love the contour wiper blade design after switching over two years ago.
Old Sep 13, 2010 | 08:50 AM
Vpanin's Avatar
Vpanin
I just bought some Bosch wipers..........took me 5 mins to put on. They work like a charm
RomanTPA's Avatar
RomanTPA
what did you replace the driver side with? from reading around it sounds like some weird design that you cant find anywhere.. I dono havent taken it off yet, but i will need to soon. I hope the RainX latitude will work. I absolutely love those.
Old Sep 14, 2010 | 06:32 AM
votru's Avatar
votru
^^^^ I'm using Anco, don't know the exact number or model as been like six month since the replacement.
Old Sep 14, 2010 | 07:28 AM
TJW98LS's Avatar
TJW98LS
I use Rain X Latitudes. They do me well.
Vi-Tuyen
LX - 3rd Gen (2008-2021)
May 14, 2024 09:27 AM
PecosBill
Aug 20, 2008 09:03 PM
portion
Jun 9, 2008 09:16 AM
1stgenGSb
GS - 1st Gen (1993-1997)
Sep 19, 2006 09:22 PM
Ucantry
Jan 20, 2005 04:18 PM
