BUG !!!!! What the......
Old Sep 2, 2010 | 06:01 AM
LexusJoey's Avatar
LexusJoey
Default BUG !!!!! What the......
This morning when I went to get gas, I found this INSIDE the headlight assembly. It is irking me. Is this going to be a 5 hour job just to get rid of it?
How did it get in there to begin with? Besides the holes for the lights, I thought they're enclosed.
Attached Thumbnails BUG !!!!! What the......-img_0881a.jpg   BUG !!!!! What the......-img_0882a.jpg   BUG !!!!! What the......-img_0883a.jpg
Old Sep 2, 2010 | 06:52 AM
Boomer01's Avatar
Boomer01
That sucks! You're going to have to heat it up and pry the housing apart to get it out
Old Sep 2, 2010 | 07:00 AM
Bocatrip's Avatar
Bocatrip
I thought I was unlucky when I found a perfectly preserved fly inside the back light assembly on the side that wraps around the rear fender. I have absolutely no idea of how to get it out as it appears to be in a sealed area. I too would love to get information on removing it as everyone seems to comment on it.
Old Sep 2, 2010 | 07:05 AM
DDLexus's Avatar
DDLexus
you might try to use an air compressor and spray around the outside and inside to determine where the bug gained access. It might also dislodge 'em and put him in a less noticeable spot.
Old Sep 2, 2010 | 07:15 AM
Jabberwock's Avatar
Jabberwock
can you pass a rubber tube in there thru the light bulb opening? Attach a reducer onto a shop vac and then attach a rubber tube to it. Feed tube end it into the headlight housing and fish around a little, it should pull the bug out.
Old Sep 2, 2010 | 08:10 AM
LexusJoey's Avatar
LexusJoey
Good call. Take the housing out and try and blow it out.
Old Sep 2, 2010 | 08:53 AM
junjdm's Avatar
junjdm
damn that sucks...i wouldn't nec. say to open your headlight...if he got in...he should be able to get out...unless he's dead.....maybe get a small vaccum?
Old Sep 2, 2010 | 09:11 AM
TJW98LS's Avatar
TJW98LS
There was a guy in the LS400 forum that bought a car with a bug in one of the Radio Displays. Pretty interesting indeed.
Old Sep 2, 2010 | 10:10 AM
Lust4Lexus's Avatar
Lust4Lexus
VERY GOOD idea!
Old Sep 2, 2010 | 12:59 PM
slclexus's Avatar
slclexus
The simplicity and elegance of Jab's solution to the "headlight bug" issue shows why old guys rock.
Doc
Old Sep 3, 2010 | 12:40 AM
Playdrv4me's Avatar
Playdrv4me
If the seal on the front had failed sufficiently for a critter of that size to get through COMPLETELY IN-TACT, then you would most certainly have a fogged up headlamp from condensation (and another reason NOT to open the headlight with heat). He has to have come in from the rear, likely during the evening after being attracted to the light, then crawling all the way in and around the back of the headlamp assembly.
Bug in the radio display would happen similarly... Bug detects heat source in the radio, crawls in through the ventilation holes or some minute opening, then crawls around til he sees the display light and makes his way in there. I do not believe the LCD is adhered to the front covering completely (i.e. iphone 4) so this is not impossible. Either that or someone removed and reapplied the plastic cover at some point.
Old Sep 3, 2010 | 05:09 PM
Bocatrip's Avatar
Bocatrip
I will be taking a picture of this fly completely intact in my rear taillight assembly to get additional ideas for removal from you guys!
Old Sep 4, 2010 | 08:37 AM
CG lover's Avatar
CG lover
dang now I am going to have to be looking at those headlights closer for any illegals,,
Derry
Old Sep 4, 2010 | 02:54 PM
Playdrv4me's Avatar
Playdrv4me
Derry
Hahahaha!!!
Old Sep 4, 2010 | 02:58 PM
01LEXPL's Avatar
01LEXPL
Yeah. This seems to be an issue with all sorts of Lexus makes.
I have a spider of some sort in one of my foglights in an '01 ES300.
My dad's RX330, has a little fly inside the pass. headlight & one in the taillight assembly! lol
