HELLO EVERYONE,
TODAY I DID THE NAVI OVER RIDE.. AND PRESSED THE WRONG BUTTON...SO NOW I GETTING EREA READING WITH CHINSE WORDING...I CANT RESET THE NAVI..I TRIED THE FUSE.. THE BATTERY..TOOK OUT THE DISK...SAME MESSAGE..I WANT MY NAVI BACK
If I'm not mistaking, to get the menu you need to press "menu" then "system options" which is on lower right of the screen and then: Upper left, lower left, upper left, lower left and then lower right. The tech menu pops up and the override is the upper right button.
is this in regards to the over ride resetting everything.. or the just over ride so you can drive....cause due to the incorrect disk reading error....system options is disabled..the only thing that is operatable is climate..radio..and screen off..but i will give it a try..
YO.. WHY DONT YOU GO PLAY WITH YOURSELF OR SOME ONE...IMA GROWN AZZ MAN KIDDO.. DONT HAVE TIME FOR GAMES...NEED SOLUTIONS TO MY CURRENT PROBLEMS..NOT HERE TO INTERTAIN YOUR NO LIFE HAVING AZZ....
just tried to do it but the menu button s disabled not the option button
Might want to go back to school and take keyboarding 101. I'm not surprised you are having problems with your Navi if you can't figure out how to turn off your caps lock key.
This thread is closed... we do not allow personal insults of this nature.
miniz, I'll suggest you don't continue this trend in future threads either please.
