Brake Issue?
Old Apr 23, 2010 | 05:41 AM
El Toro's Avatar
El Toro
Default Brake Issue?
I have a 2005 LS 430 with 20 inch wheels on 245/35/20 Toyo Proxes 4 tires. The car is lowered on Tanabe NF springs and I have spacers to help clear the brakes. I have had no problems from the car or set-up in 20K miles. Recently I have been getting a little vibration while driving and braking. I also have a sound while driving and braking that is very odd to me. I can hear the sound with the windows down or up as long as the radio is off. It sounds almost as if a piece of metal (almost like a giant washer) is loose or rubbing slightly. When I took it to my mechanic, he said that due to the fact that the brakes have several metal parts the sound is normal. He told me the brakes are fine. He feels like the wheel/tire/spring set-up simply magnifies the sound, especially with the open space I have with the wheels and the low profile tires. I disagree, especially since I can hear the sound inside the car with the windows up and the radio off. A friend of mine believes this will go away after the brakes are serviced. What do you think?
Old Apr 24, 2010 | 09:18 PM
V8_Fan's Avatar
V8_Fan
My guesses:
1) Brake caliper bolts are loose (bolts are not reusable; once you loosen them, you have to replace them due to the aluminum control arm they bolt to)
2) Wheel bearing is loose
3) Missing wheel weight
Does the vibration worsen with speed? Have you tried swapping a rear wheel into that position and see if it does the same thing? If so, that eliminates a missing wheel weight.
Old Apr 25, 2010 | 01:26 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Sounds like sway bar end links or bushings. I would re-tighten everything.
If that doesn't help, you may need to replace your strut bars (this was a common issue on LS400's.)
Old Apr 25, 2010 | 04:59 AM
El Toro's Avatar
El Toro
Good answers. Thanks a ton! The vibration does worsen a bit at speed. I noticed this after the tires were rotated. I am going to the dealer this week and I will take your info!
zes
14
May 24, 2016 05:55 AM
UZ214
Suspension and Brakes
Sep 4, 2007 07:45 PM
Xevuhtess7
Apr 7, 2005 01:22 PM
