Help !! Check vsc error
Old Dec 22, 2009 | 08:18 AM
diplomacyk's Avatar
diplomacyk
Exclamation Help !! Check vsc error
Hey Guyz...I need help i have a 2005 lexus ls430 ultra luxury package while i was driving today evening on the dash display screen the error sign came up in red and a message saying check Vsc with traction off light on and Check engine too ....
What could this be
is it safe to drive with the error message on the dash saying Check vsc and red ! mark on the rpm with traction off and check engine light also on
please helpppppppppppppppp
Old Dec 22, 2009 | 08:35 AM
wildace's Avatar
wildace
see if a obd2 scanner can tell you whats wrong. i had a 02 Q45 that it happened to. it seems that it was a ABS sensor that went bad but i would assume the abs light would be on also.
Old Dec 22, 2009 | 10:09 AM
diplomacyk's Avatar
diplomacyk
Bro i think its the o2 sensor ....
i dont know where the o2 sensor is located and is it safe to drive the car like this and how much would it cost me to replace it
help plzzz
Old Dec 22, 2009 | 08:29 PM
diplomacyk's Avatar
diplomacyk
Question
Can anyone answer my questions pleaseeeeeeeeeeeee
Old Dec 23, 2009 | 06:49 AM
Kansas's Avatar
Kansas
I think Wildace answered your question to some extent. Have the stored error code(s) read and take the appropriate action.
An endless list of issues can cause the CEL and VSC/Trac warnings ... TPS/PPS, battery, etc., etc. -- way too many to guess at the cause.
Yes, the car is "safe" to drive. I wouldn't want to drive without VSC and Trac in the snow or even in rain but I'm guessing you don't have that problem as much in UAE.
Old Dec 23, 2009 | 07:09 AM
diplomacyk's Avatar
diplomacyk
Hey Guyz Well I took ma Ride to an outside dealer ( a small shop -Lexus Specialist ) and they charged me 28$ for the computer test and the problem what it said was as follows :-
Bank 2 O2 Sensor 2 ..its on the right side under da passenger seat ..they said its not the manifold sensor its under da front passenger seat its the 2nd o2 sensor ...
well for a new o2 sensor its for 100 $ and for fixing it another 55 $
and then the vsc message would go offf and they do tuning for OEM hydraulic setting too ..lowering the car as i want it ..i.e i wouldnt need to buy an air data controller
Old Jan 7, 2010 | 03:41 AM
roumieh200's Avatar
roumieh200
Where did you do that, i wanna do it tooo. I live in sharjah Dude..
Old Jan 8, 2010 | 02:55 AM
diplomacyk's Avatar
diplomacyk
Smile
Wow gr8 2 see sum1 4rm my town
well dude what ride you got and whats the problem you facing ??
Old Jan 15, 2010 | 06:22 AM
bboarder71's Avatar
bboarder71
This just happened on my '06 GS300
any thoughts
Old Jan 15, 2010 | 12:34 PM
Jabberwock's Avatar
Jabberwock
I think its basically the same answer when you get one of these codes. Take it in and get the code read - in most cases the code will specify which part is broke and needs repair or replacement. Until you get the code read and come back with a specific defined problem no one can comment or provide thoughts.
Old Jan 17, 2010 | 09:27 AM
bboarder71's Avatar
bboarder71
so 3 days later
vsc , cel and brake light all on normal driving and a tightened gas cap. end up going to dealer. they check everything say tighten the gas cap and explains how we didnt wait long enough for the light to clear.
Old Jan 17, 2010 | 09:37 AM
caddyowner's Avatar
caddyowner
On GM cars, it requires something like three full-temp operating cycles to clear the gas cap code. Each cycle consists of starting the car when cold, driving the car, and allowing the coolant to reach full operating temperature before shutting it off.
Ford has a better idea on my Lincoln: a dedicated idiot light for the gas cap.
Old Jan 17, 2010 | 11:34 AM
djsweetboi's Avatar
djsweetboi
yeah when i lower my dad ls430 lexus his vsc pop up
Old Oct 21, 2010 | 10:31 AM
gs3002006's Avatar
gs3002006
My 06 just gave me this error. $200 later it was fixed- needed a new gas cap.
JuanM07
Jul 4, 2017 12:55 AM
chico55
May 15, 2014 08:24 PM
Jrud87
Dec 29, 2011 10:38 AM
StanVanDam
Jun 1, 2010 12:19 PM
NikSC
May 16, 2009 02:31 PM
