04 – Side mirror remote control problem
Old Oct 27, 2009 | 04:19 AM
Yaff's Avatar
Yaff
Default 04 – Side mirror remote control problem
On the mirror control panel, when the center switch is pointing left, no problem with the driver side. But when on the right side. I can’t adjust the passenger side mirror.
I had to manually forced it in position. I hope I didn’t break anything.
When side mirrors are on automatic, the passenger mirror is still folding in and out during power on/off. It also sill look down for sidewalk view in reverse and return in position when on Drive.
So I suspect a defective remote control switch.
Did anyone got similar problem? If yes, how much should I expect to pay for a fix?
Old Oct 27, 2009 | 06:22 AM
tcjeffri's Avatar
tcjeffri
See this thread. I cleaned my switch and it works like a charm. I wouldnt suggest forcing it into place anymore...
https://www.clublexus.com/forums/ls4...r-adjujst.html
Old Oct 27, 2009 | 06:35 AM
AlexusAnja's Avatar
AlexusAnja
Default Bad switch...
Originally Posted by Yaff
On the mirror control panel, when the center switch is pointing left, no problem with the driver side. But when on the right side. I can’t adjust the passenger side mirror....?
Try the cleaning as previous poster said, and definitely don't force the mirror. It surely doesn't sound like the mirror is bad since it's moving all fine, just it's not adjusting when you use the switch.
Didn't you try adjusting the mirrors before getting this from the old man?
Old Oct 27, 2009 | 07:04 PM
Yaff's Avatar
Yaff
That mirror thread is an excellent advice. Thanks!!!!!!
I just spent an hour cleaning the connectors and trying different things. Although I’m still having the issue, at least I found the culprit. Unlike the initial poster in the thread, in my case it is not the main connectors, but the right-left side selector. If anything can be done, I have to disassemble the switch itself to fix it. Unfortunately I didn’t succeed.
So as I posted there I have a temporary workaroud. I can get the mirror to ajust if I apply the right pressure on the center switch. But I might as well give up and spit the 280$ for that darn switch.
I didn't ... Now don't flame me, I didn't even drove his car myself.
He gave me a ride and I was paying attention to all the details.
Then I got a so call full inspection at a Lexus dealer.
Old Oct 27, 2009 | 07:40 PM
AlexusAnja's Avatar
AlexusAnja
...Then I got a so call full inspection at a Lexus dealer.
So called is right... if they missed this, who knows what else they missed. Did you kick the tires?
Old Oct 28, 2009 | 11:22 AM
Yaff's Avatar
Yaff
Who knows what else they missed. Did you kick the tires?
Better than that. I changed the *****. Now I'm clear of any surprises, am I?
Have you seen the movie "Choke"?
This med student dropout is at stripper club. He sees a nice blonde with a mole on her leg and he says to her... Hey babe you better have that mole checked out. Blondes are running at higher risks of skin cancer.
Next time he returns he sees her again. Hey what did you do to your hairs?
She replies you scared me with that blonde thing. So I got them dyed.
jamsvet
Sep 17, 2025 05:36 PM
Hotrod70
Sep 7, 2015 03:10 AM
mar1
Oct 16, 2014 10:38 AM
Bostonfan
Sep 5, 2013 09:58 PM
ILOVEGIRLS
May 4, 2007 06:28 PM
