center dash rattle
Old Sep 16, 2009 | 12:43 AM
gpb's Avatar
gpb
Default center dash rattle
There is an intermittent center dash rattle on my '04 LS430. Anyone else that has or had a similar problem?
Old Sep 17, 2009 | 04:14 PM
SerasLibre's Avatar
SerasLibre
Nope, but if you/someone removed any of your center console units, one of the bolts might have fallen off during installation or while driving (not tightened to spec). It is fairly easy to remove all of the center console panels and electronics. The problem shouldn't be too difficult to trace.
Old Sep 17, 2009 | 11:27 PM
Griff48's Avatar
Griff48
I have a rattle traced to somewhere in the buttons on the right side of the screen. I have taken the Nav out, taped and tightened everything in there. It stopped the rattle for a few weeks but has since come back. A very light touch between the buttons and the passenger-side temp control stops it until you take you hand away. Drives me nuts.
Old Sep 20, 2009 | 08:03 PM
Zetroc's Avatar
Zetroc
Similar problem on my 04LS..mine stops when I press the plastic around the right side of the nav screen. Tech at dealership said it would require removal of the center console w/no guarantee fix would last. The fit is too tight to force felt into the gap.
Old Sep 22, 2009 | 06:58 PM
gpb's Avatar
gpb
I found out what may be all or part of the problem. The satellite box and adapter were not secured when added under the dash/in front of the console. All is quiet now, and I hope it stays that way!
levinsoy
GX - 1st Gen (2003-2009)
14
Aug 1, 2021 05:40 PM
Isfsport11
Sep 28, 2016 04:52 AM
jaxxx
May 29, 2011 02:53 PM
johnnyrod
Jan 2, 2008 02:17 AM
iS250pearl
Nov 21, 2006 05:44 PM
