offset ?
Old Jul 7, 2009 | 10:03 PM
SDxLS430's Avatar
SDxLS430
Default offset ?
20x10 +7 Standard Disk
20x11 +6 Low Disk
anyone running anything similar to these specs? how much body work would be needed with stretched tires and UAS or coilover suspension?
Would my fender stick out more then the rear quarters if I pulled both of them to fit these wheels?
Thanks for any help.
Old Jul 7, 2009 | 11:04 PM
BIGGZ's Avatar
BIGGZ
im not close to rolling on those kinda specs but i'll try and help.with the help of a wheel offset calculator i came up with these numbers.compared to my specs,the fronts would come out an extra 34mm's and the rears would come out an extra 24mm's.heres a picture of my car slammed on "L" mode with the Datasystems controller.
visualize the wheel coming out 34mm more,about 1 1/4"
visualize the wheel coming out 24mm more,about 1"
so to answer your questions,yes you are gonna have to pull the hell out of you rear quarters or do custom flares.even the front,maybe a minor pull will work.oh and im not sure if standard disk can clear our front brakes.btw,do you mind sharing what wheels you looking at?they sound tasty!
Old Jul 7, 2009 | 11:10 PM
BIGGZ's Avatar
BIGGZ
oh i could be wrong but the front wheels might be too wide,it may rub the inside fender wells.again,i could be wrong though.
Old Jul 8, 2009 | 04:22 AM
sojah's Avatar
sojah
is the larger the offset number the more fat (aggressive) or far the lip sticks out?? or is it the smaller the offset number the more aggressive and wide the lip would be??
Old Jul 8, 2009 | 04:51 AM
BIGGZ's Avatar
BIGGZ
^^^the lower the offset number,the more the wheel will stick out and have a bigger lip.
Old Jul 8, 2009 | 12:57 PM
beangrower's Avatar
beangrower
sounds like ur gonna run some leon hardiritts..??
anyways, here is my old setup:
20x9.5 +1 offset
20x11 +6 offset
in this pic, its stock fenders (no pull...no roll...no cut) on 225/35 fronts and 245/35 rears with about 4 degrees negative camber in the rear...and i think 1.5 neg camber front?
hope this helps.
Old Jul 8, 2009 | 01:11 PM
sojah's Avatar
sojah
ahhh ^ ^ ^ camber...
Old Jul 8, 2009 | 04:41 PM
SDxLS430's Avatar
SDxLS430
hey breangrower, I didn't know your wheels were the same size specs I was looking into besides the front, I wanna move it up to a 10. I know your running those expensive control arms for the negtaive camber but I'm just gonna go with the pull and radiused rear fenders since I got a hook up with a body shop and I don't wanna deal with early tire wear.
btw, how much did you spend on the custom arms?
thanks everyone for the help, It's hard to do some measuring and test fitting when I don't have the car yet. but as soon as I get her I'll be able to fit some nice 20's and UAS and hopefully the g-answer lip kit.
Old Jul 8, 2009 | 04:43 PM
SDxLS430's Avatar
SDxLS430
Leon Hardiritt Ordens 20'' step lip just like beangrowers. or I was thinking the trafficstar DTS.. whatever will flow best
Old Jul 9, 2009 | 11:50 AM
beangrower's Avatar
beangrower
arms cost me almost 2grand installed.
fronts should be no problem...the rears, u might be able to get away with a pull and radius and stretch tire. i think racinstylez went this route but he did a lil negative camber in the rear. u can ask him how he did it.
for the fronts, ur gonna get the same lip size from what i had, just wider rim (better chance of stretching tire even more) and about 0.35mm wider from the fender. becuz roads are really bad where i live, i didnt see the point in stretching the front w/ a smaller tire so 9.5" was good enuff.
Old Jul 9, 2009 | 01:30 PM
sleeperek9's Avatar
sleeperek9
would these work with stock fenders 20x9.5 +4 20x11 -3 in standard disk. im looking at the Work LS406
Old Jul 9, 2009 | 05:10 PM
SDxLS430's Avatar
SDxLS430
anything will work, it's just how much are you willing to spend to make them fit?
but to answer your question, you're definitely gna have to pull your fenders in the rear and take it to a body shop or get the custom control arms that beangrower has and a slight pull maybe in the back with stretched tires.
for me I'm not into the whole camber look. replacing tires every 3-4 months is gna be a ***** and it just looks like your suspension is broken. that's just me though.
Old Jul 9, 2009 | 05:36 PM
beangrower's Avatar
beangrower
i would like to see that. those were gonna be my next set o' wheels. however, the LS line costs a grip and i need to get a house. so yeah, i say do it. make'em fit.
btw: i wonder if the standard disk is gonna clear the stock ls430 front bbk?
Old Jul 10, 2009 | 06:33 AM
sleeperek9's Avatar
sleeperek9
That's what I was wondering also. They have them in deep rim disk and a big caliper disk
Supraman18
Mar 5, 2011 05:11 PM
dboyz85
Aug 30, 2009 11:54 AM
Net Junky
Jun 20, 2008 11:30 PM
Kohinoor
Wheels, Tires & Brakes Forum
Dec 4, 2006 09:46 AM
