Removing passenger side switch asymb
Old Jun 15, 2009 | 11:03 PM
bigcory's Avatar
bigcory
Default Removing passenger side switch asymb
When my music is up, the window switch area rattles under heavy base. I want to remove the switch & wood to see if I can reduce it.
How do I remove that part from the door, does anyone have any experience with it?
Old Jun 16, 2009 | 04:35 AM
AlexusAnja's Avatar
AlexusAnja
You mean the wood piece right? It just snaps in with retainers at the side closer to the bottom and "hooks" into the trim in at the top near the dash. I wouldn't use a screwdriver or anything, but a fish line perhaps and loop under the trim on the bottom side and just pull straight up. It should unlatch and then you lift and "unhook" out.
Old Jun 17, 2009 | 08:31 PM
bigcory's Avatar
bigcory
yep, thats the piece. I'll give the fish line a try and see what comes of it.
Old Jun 22, 2009 | 07:42 PM
bigcory's Avatar
bigcory
you sir...are the man! Thank you for the picture!
Old Jun 26, 2009 | 05:55 AM
daddykay24's Avatar
daddykay24
Did you find a fix? I have the same problem with mine and could not find a solution.
Old Jun 26, 2009 | 08:53 AM
bigcory's Avatar
bigcory
on the agenda for today...i'll let you know how it goes
bweldon
RX - 1st Gen (1999-2003)
Sep 7, 2017 03:36 AM
davidma415
Jul 23, 2015 06:32 AM
Bombsquad
Oct 7, 2007 03:30 AM
SlowGS3
GS - 1st Gen (1993-1997)
Jun 7, 2005 01:00 PM
SlowGS3
May 9, 2005 12:45 PM
