LS430 multiple electronic problems.
Old May 16, 2009 | 06:21 PM
gurmin's Avatar
gurmin
Default LS430 multiple electronic problems.
Got problems with electronics.
While I was driving, noticed, that gas meter turned off. At the same time the following equipmnet stopped working:
Steering wheel controls of audio system.
Horn
Windshield washer + wiper switch
fog lights
Steering wheels teleskoping
Trunk and fuel opening ( cannot open trunk from cabin and from keys)
Side mirrors regulators.
Fuses intact
Old May 16, 2009 | 07:38 PM
Nauticalx's Avatar
Nauticalx
You either have a bad ECU, battery, or a flood vehicle...
Old May 16, 2009 | 08:33 PM
gurmin's Avatar
gurmin
I have this car for 1 year. So flood can excluded
Old May 16, 2009 | 08:37 PM
gurmin's Avatar
gurmin
By the way, what ECU stands for?
Old May 16, 2009 | 08:59 PM
Tee's Avatar
Tee
ELECTRONIC CONTROL UNIT (ECU)
Definition: The Electronic Control Unit (ECU) controls the fuel injection system, ignition timing, and the idle speed control system. The ECU also interrupts the operation of the air conditioning and EGR systems, and controls power to the fuel pump (through the control relay). The ECU consists of an 8-bit microprocessor, random access memory (RAM), read only memory (ROM), and an input/output interface.
Based on information from the input sensors (engine coolant temperature, barometric pressure, air flow, etc.), the ECU determines optimum settings for the output actuators (injection, idle speed, ignition timing, etc.).
Old May 16, 2009 | 10:33 PM
SH212's Avatar
SH212
Dances with goats
meh, Try and see if your battery is the problem...
My battery was dieng on me and weird ish started happening too... most local auto shops can do a free check
Old May 17, 2009 | 03:14 AM
gurmin's Avatar
gurmin
In a case of dead battery, shoud I have problems with starting car? Because I can start and drive car with no problems.
Old May 20, 2009 | 09:34 AM
gurmin's Avatar
gurmin
Default Diagnostic charge
I took my car to Lexus service. Charged for dignostics - $230. It is second day and they still can not find the problem.
Representative told me, that if it will take more time for diagnostic, they will charge me more for diagnsotic procedures. Question - is it legal?? They charged me already. And if somebedoy cannot find problem in 2 days, should I pay, for the fact that somebody not realy qualified to do their job???
Tell me if I'm wrong.
Old May 20, 2009 | 10:47 AM
Tee's Avatar
Tee
You need to speak to the service manager tell him I already paid for the dignostics, and you will not be paying again when they have not found the issue in the first place.
Old May 20, 2009 | 12:04 PM
GS3Tek's Avatar
GS3Tek
Horn
fog lights
Fuses intact
haven't had this problem so no help from me
How about those bigger amperage fuses, like those 60 amp kinds???
Old May 20, 2009 | 01:11 PM
So Philly1's Avatar
So Philly1
Thats a really weird problem. Sounds like it may be a coincidence that all of those happen at once but then again what do i know???
Old May 20, 2009 | 02:57 PM
gurmin's Avatar
gurmin
All fuses are OK, I checked by myself before going to dealer. Checked one by one Smalls and biggies.
Very weird. For example, I cannot adjust mirrors, but when I'm putting on reverse, mirrors turning down, so power really going. Talking about control module, all functions described above, regulated by different modules. Is it possible, that all of them went down at the time? If yes, how it's possible? Car wasn't flooded.
We'll see what they will found. Day#3 started 3 days at dealership and no answer so far.
Old May 20, 2009 | 07:23 PM
campisi's Avatar
campisi
Highly unlikely. One commonality among the different modules is the power supply - the battery. I would definitely do some kind of a load check on the battery, not just measure the voltage but measure it under some kind of load - maybe just with the car running. The stealer should be able to do that, if they haven't already.
Old May 20, 2009 | 08:59 PM
Red Square's Avatar
Red Square
most likely a loose/cut circuit in the interior harness or a bad switch (somewhere).
Old May 23, 2009 | 07:53 AM
Nauticalx's Avatar
Nauticalx
Unless you've been the owner since day one or bought it from someone you trust, you can't possibly be sure that the car hasn't been flooded...
