Rear Climate Control Operation
Old Jan 18, 2009 | 10:24 PM
DNC's Avatar
DNC
Default Rear Climate Control Operation
Is the rear air purification system activated anytime the front climate control is on or does the rear apurification system only work when the rear system is on? I ask because I occasionally smoke a cigar while driving and try to keep the odor down as much as possible. Venting by window or sunroof helps only so much. Thank you.
Old Jan 19, 2009 | 05:26 AM
sojah's Avatar
sojah
just my opinion which probably doesn't count for much but i always thought that the rear air purification system thing was only on when air was passing through the rear system, if its off i would assume that no air is being filtered. i could be horribly wrong though, cuz you know what they say about making assumptions.
Old Jan 19, 2009 | 06:47 AM
Boomer01's Avatar
Boomer01
I think it is only on when the rear vents are turned on.
Old Jan 19, 2009 | 12:18 PM
BNR34's Avatar
BNR34
Only on when the rear AC is on.
Old Jan 19, 2009 | 08:18 PM
KILLERGS4's Avatar
KILLERGS4
ditto, hard to tell if this thing really works.
Old Jan 19, 2009 | 08:20 PM
airtime's Avatar
airtime
CL Folding 1,000,000
+1, only when the rear air is on.
Old Jan 19, 2009 | 10:22 PM
DNC's Avatar
DNC
So the air purification system only works when the rear A/C is turned on and has nothing to do with the rear heat?
Old Jan 20, 2009 | 05:00 AM
sojah's Avatar
sojah
i hit my climate button this morning, and at the bottom it says rear ac/air purification system, and i guess its either on or off.
Old Jan 20, 2009 | 08:02 AM
BNR34's Avatar
BNR34
A/C is both cooling and heating
Old Jan 20, 2009 | 10:13 AM
GSoup's Avatar
GSoup
CL Folding 10,000
You can hear it on, if your not in a noisy place.
Old Jan 21, 2009 | 02:07 AM
KILLERGS4's Avatar
KILLERGS4
when you turn on rear climate control, you only get cold a/c. The rear vents (up in the air) only blows cold air, works hand-in-hand with cool-box. Therefore you can use cool-box in the summer, b/c you don't want cold air in the back during winter.
mak8504
Jun 20, 2019 10:56 AM
redrocks
GX - 1st Gen (2003-2009)
Apr 18, 2013 04:07 AM
uae
Sep 13, 2007 01:14 PM
Lexs400
Jan 3, 2005 09:50 AM
