2001 LS430 Window Noise
Old Oct 17, 2008 | 11:58 AM
general98's Avatar
general98
Default 2001 LS430 Window Noise
Help - I have a window noise that is driving me crazy. It comes from the driver side front window and only happens when the window is rolled all the way up. It sounds like a cracking / popping when going over any bumps. If I lower the window the slightest bit, the noise is gone. But, that isn't a great solution at highway speeds because of some wind noise. Any help would be appreciated - it is driving me nuts.
Disclosure - the car has been in an accident before, so could it be frame related somehow or does it sound like something else?
Old Oct 17, 2008 | 12:30 PM
SH212's Avatar
SH212
Dances with goats
not sure because of your accident..
but i had that a lot.. i simply cleaned the windows with windex and it stopped...
Old Oct 17, 2008 | 01:23 PM
general98's Avatar
general98
I will certainly try that soon - I hope it is as simple as that. I won't be able to try until Monday because I am away but will let you know. Thanks for the feedback.
Old Oct 17, 2008 | 02:34 PM
SH212's Avatar
SH212
Dances with goats
make sure you dont have tints or that windex while wipe those tints right off!
Old Oct 20, 2008 | 08:51 AM
Boomer01's Avatar
Boomer01
Windex will not strip tint off a window. I have heard similar creeking when I drive out of a driveway (changes in levels of pavement). Not sure if it is the same noise but it is probably just the car twisting.
Old Oct 20, 2008 | 01:07 PM
Salil022's Avatar
Salil022
I had similar noise on my 04 & 03 LS...Seems like it was coming from the seals
Old Oct 20, 2008 | 07:42 PM
general98's Avatar
general98
Boomer01, it is definitely happening on changes of pavement height, etc and does seem like it is the car twisting or something along those lines. Did you ever do anything about it or just leave it?
Salil022, did you do anything with the seals, or would you recommend doing anything? Any idea on the price for that type of work?
Old Oct 21, 2008 | 02:48 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
I have a similar situation on my GS. If its the same problem i'm having, its due to a improper window alignment. This became frustrating as i drive my GS on long trips often, not to mention it became very loud after getting used to the laminated windows on the LS.
I took off the door panel and tried to fix the situation many times, without any success.
I have to kinda hold the window and push it towards the rear of the car (while i'm in the drivers seat) while rolling it up, to ensure it closes properly... that took care of it... problem is i have to do this every time i roll up the window if i'm going on a highway.
I also followed this DIY from the GS forums and had GREAT success with window nosies at highway speeds, the car is much quieter now:
https://www.clublexus.com/forums/sho...ght=wind+noise
Old Oct 21, 2008 | 05:15 AM
Boomer01's Avatar
Boomer01
I haven't done anything to fix the problem. The popping or cracking noise only happens on dips or bumps so it doesn't bother me much. I didn't really think it was anything wrong.
Old Oct 21, 2008 | 05:27 AM
junjdm's Avatar
junjdm
I have heard the same issue w/ my car....its kinda weird, but it only happens once in awhile, really doesn't bother me too much, esp knowing its a common problem now.....
Old Oct 24, 2008 | 08:06 AM
general98's Avatar
general98
I ended up taking my car to the dealer to have them look at the window noise issue and they were able to fix it in under an hour. They performed a door frame adjustment and it is good as new.
RRocket
Mar 30, 2017 08:36 PM
karolgt
Sep 27, 2014 05:58 AM
1stgenGSb
GS - 1st Gen (1993-1997)
Oct 11, 2006 06:12 PM
Booyah
Nov 18, 2004 11:14 PM
tomrx330
Nov 16, 2004 12:06 AM
