Side Mirrors LED Light Install w/ Pix
Old Aug 11, 2008 | 09:09 PM
mkivowner's Avatar
mkivowner
Originally Posted by airtime
I'm right behind Bellevue BMW or across from Acura of Bellevue.
Ordered it from www.superbrightleds.com .
Yes, that where I got it from...
Old Aug 11, 2008 | 09:17 PM
JemmyTran's Avatar
JemmyTran
another great write up thanxs
Old Aug 11, 2008 | 09:18 PM
airtime's Avatar
airtime
CL Folding 1,000,000
Originally Posted by Tee
31mm festoon will handle the dome light.
Tee, you gotta show me how to get to the dome light. I tried but didn't want to scratch anything up. I couldn't budge the cover off. What's the trick?
I did the doors also with the WHP ones. The regular 5 or 6 LED are ok but the WHP really shine. Next would be the map and the dome for me
Old Aug 12, 2008 | 04:41 AM
Tee's Avatar
Tee
Airtime,
I used a small flat head screw driver on all eight clips located near the edge of the light cover. The platic clips that hold the cover in place are flexiable, so when you bend them they flex back to hold the cover in place. Start near the corner first on one side, then work your way around until the cover pops off or just pull it off. Use a samll screw driver b/c a big one will leave a preasure dent on the sides of the light housing, the plactic cover is hard plactic so don't worry about breaking it.
I picked up my dome & rear lights here.
http://www.coolbulbs.com/cool_accessories.asp
The dome is very bright!!!
The maps and rears are not as bright as the dome.
Old Aug 12, 2008 | 06:00 AM
Boomer01's Avatar
Boomer01
Did you have to apply more adhesive to the mirror when you put it back on or did it stick just fine? I'm worried about the stickiness wearing out and the mirror falling off.
Old Aug 12, 2008 | 08:01 AM
airtime's Avatar
airtime
My thoughts are there are enough gooey stuff that it should hold. Also, the outer trim ring helps hold the mirror in place as you have to unclip it as show in the first couple of images. But I guess ultimately, you can squeeze off a couple of dollops of silicone on the back to insure it.
Old Aug 12, 2008 | 09:52 AM
GS3Tek's Avatar
GS3Tek
Thanks for the write up airtime
I initially thought you could access it from underneath-never looked into though, but now I know
Old Aug 12, 2008 | 10:14 AM
junjdm's Avatar
junjdm
good write up, I did mine the hard way...hahaha..did mine a couple of months ago............but i love it....looks so much cleaner and better
Old Aug 12, 2008 | 12:00 PM
Tee's Avatar
Tee
What no pics??!
Look at you holding out on us.
Old Aug 15, 2008 | 09:08 PM
Tee's Avatar
Tee
Okay my LED's came in today and i installed soon as I got home tonite, they look great matched up with the dome LED! Here are some pics.
***UPDATE*****
I finally found some brighter BA9 LED's to replace the not so bright ones, the new ones make great map lights and rear interior lights.
You can buy them here.
http://cgi.ebay.com/ebaymotors/_Car-...=1218859685687
Thx again Airtime for the great write-up and pics!
Old Aug 15, 2008 | 09:47 PM
airtime's Avatar
airtime
Tee, those rear passenger lights are bright. I'm going to have to order some my self.
Old Aug 16, 2008 | 02:38 PM
Tee's Avatar
Tee
Cool!
BTW did you swap out your dome light yet?
Old Aug 16, 2008 | 07:52 PM
airtime's Avatar
airtime
Cool!
Not yet. I want to place an order for everything at the same time as for the exterior LED, I was ordering onesies twosies and get hit with shipping cost each time. Was thinking about swapping out the daylight running lights to LED too, though I kinda like the yellow as its more noticeable during the day. Dave.
Old Aug 16, 2008 | 08:11 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Very nice writeup
Been thinking of doing the license plate bulbs on mine but haven't taken time to research bulb type and if there's a diy like this one (if even needed) yet.
Old Aug 17, 2008 | 08:34 AM
Tee's Avatar
Tee
I Was thinking about swapping out the daylight running lights to LED too, though I kinda like the yellow as its more noticeable during the day. Dave.
I had some amber 194's focused LED's
left over from when i had the 4Runner, I used them to replaced the stock bulbs. I like the look so i left them in.
Originally Posted by DaveGS4
Very nice writeup
The licence plate LEDs (194) are easy to do, you will need to remove the trunk panel to get to them, it is easy to remove due to the snap screws on it. I can tell you will love the clean look over the stock ones.
