Would'nt Start (Panic)
Old Aug 9, 2008 | 07:30 AM
Big Joe's Avatar
Big Joe
Question Would'nt Start (Panic)
Got in the car acted normal, got to the store went in stayed about 15 min and came out and car would not start. Tried the key and still would not start. The key turns on and everything works but it won't go on over to start. Waited about 5 mins and it started up like nothing was wrong. What is going on?
PS: The car is UL 430 with electronic key.
Thanks Joe
Old Aug 9, 2008 | 08:07 AM
junjdm's Avatar
junjdm
man....i have no idea......thats crazy
Old Aug 9, 2008 | 09:35 AM
SH212's Avatar
SH212
Dances with goats
what year is it?
Old Aug 9, 2008 | 09:37 AM
GS3Tek's Avatar
GS3Tek
Could be early sign of:
1. dieing battery
2. starter???
3. loose battery connections
4. a rare fluke
Old Aug 9, 2008 | 09:43 AM
Big Joe's Avatar
Big Joe
Default Battery
New battery in car after this happened once before. Sorry it's a 05. Could the fob battery be going down.
Old Aug 9, 2008 | 10:15 AM
SH212's Avatar
SH212
Dances with goats
maybe the starter thats my geuss
Old Aug 9, 2008 | 10:49 AM
blacksc400's Avatar
blacksc400
Car Chat Moderator
Not the starter, if it is, you can turn the key but no click from the starter.
Maybe the battery in the key???
Or an once in the blue moon fluke???
Old Aug 9, 2008 | 12:04 PM
ChocosLS430's Avatar
ChocosLS430
My guess would be a loose battery connection. I had that problem before on my GS300 and after cleaning and tightening the battery bolt, everything worked fine after that. 2nd guess would be battery cells are going dead.
DanozLS430...
Old Aug 9, 2008 | 01:03 PM
Big Joe's Avatar
Big Joe
Default Key **** on dash
I'm sorry I didn't explain myself better. The key **** on the dash would not go over far enough to engage the starter. I tried pushing in and it still would not go into the start mode. See first post for the rest.
PS: Do you have to push in from the beginning to go to the start position? Or can you have the key in the acc. mode and than push in for it to start. Thanks Joe
Old Aug 9, 2008 | 02:30 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Maybe the steering wheel was locked?
Old Aug 9, 2008 | 02:42 PM
encore888's Avatar
encore888
Was the LS 430 parked on an incline? There is a safety feature which prevents the key **** from turning to start mode, if the car is parked at an incline and the steering wheel turned to one side. This is to prevent the car from sliding out of position when starting; I experienced this once on an LS 430 when parked at a gas station (very slight angle, but still) and Lexus Roadside Assistance advised that the car not able to start (key **** would prevent ignition) was intentional; just straighten the wheel and the car could start normally IIRC. Nothing wrong with the car in that instance.
Old Aug 11, 2008 | 09:48 PM
VQT's Avatar
VQT
Turn the steering wheel a little while turning the start ****. Grand LS 4 maybe correct on this.
Old Aug 11, 2008 | 11:15 PM
Lexophile's Avatar
Lexophile
The steering wheel not straight on an incline would be my two pennyworth!
Old Aug 12, 2008 | 03:17 PM
Suneet's Avatar
Suneet
Had this "problem" in my LS400 and my Sienna--- it was usually just turning the wheel. I do remember freaking out the first time I encountered it.
tomb020871
Apr 5, 2017 08:56 AM
chipmcclur
GX - 1st Gen (2003-2009)
Jan 14, 2016 04:47 PM
Fredrico55
RX - 1st Gen (1999-2003)
13
May 3, 2011 09:47 PM
zero44
GS - 1st Gen (1993-1997)
Mar 26, 2010 08:37 PM
slugmike
Dec 18, 2005 11:00 AM
