2002 ls430 center console removal
Old May 16, 2008 | 04:49 PM
ptjetpilot's Avatar
ptjetpilot
Default 2002 ls430 center console removal
has anyone removed the center console on a new body LS. my car has an xm radio mounted to the right side of the radio stack I'd like to remove. need to get access to the side of the radio stack where it is mounted.
thanks
Old May 16, 2008 | 06:40 PM
Bdragon007's Avatar
Bdragon007
If I can remember correctly, You first start to pop out the section where the sunshade button and heated/cool seat is with flat head screwdriver. Then there are 3 crews right below the next section where the Power/ height/ sport button are (phillips+ 10mm i think) will free it up. Then come the hardest part, the radio itself and cd changer is all one unit (my has nav so I don't know if it's different on no nav) you will have to pop out the two climate control buttons on the each side of the dash to access the 10mm screw in there, then a couple screw below the Cd changer will free everything up.
Hope this will help, just try to think of this out of my memory so if I'm wrong hopefully ther will join in. Good luck!
Old May 16, 2008 | 07:13 PM
ptjetpilot's Avatar
ptjetpilot
thanks for the reply this car does have NAV
biggdadd58
Jan 8, 2019 07:42 PM
Griff48
Jun 14, 2009 07:45 PM
bruceko
Jan 17, 2009 10:43 PM
newday95
Dec 25, 2008 03:35 PM
rharse
Aug 2, 2008 05:41 AM
