Subwoofer rattleing
Old Jul 23, 2007 | 07:35 PM
KINGLS430's Avatar
KINGLS430
Default Subwoofer rattleing
When the bass hits my subwoofer is ratteling not like the bump sound but like an annoying sound like theres somthing vibrating on it i checked it and theres nothing on it what could it be?
Old Jul 23, 2007 | 09:51 PM
bb430's Avatar
bb430
Blown subwoofer? Take the grill off and check it, there may be separation from the paper cone to the rim.
Old Jul 24, 2007 | 06:28 AM
KINGLS430's Avatar
KINGLS430
ok if i did blow it should i just upgrade to the jbl or should i replace the mark levinson?
Old Jul 24, 2007 | 08:09 AM
bb430's Avatar
bb430
It's up to you but understand the ML subwoofer IS a freeaired not enclosed subwoofer. I just glued it with contact cement and so far so good, there are talk of rebuilding it with kit or send out for rebuild. Personally I would keep using the ML subwoofer whether rebuild or replace.
Old Jul 24, 2007 | 08:33 AM
KINGLS430's Avatar
KINGLS430
So your saying i could just glue it back togther and it would work and if not how much is it for a replacement ML subwoofer?
Old Jul 24, 2007 | 08:34 AM
FLIPPU's Avatar
FLIPPU
If you have the sunshade..that sometimes will cause the rattle..or something on the rear deck.
Mike
Old Jul 24, 2007 | 08:47 AM
junjdm's Avatar
junjdm
I got the JL 10" fits perfect in it, only paid $80 for it, its better than the trying to fix it hassle. Easy plug in play! sounds great too!
Old Jul 24, 2007 | 08:59 AM
bb430's Avatar
bb430
I did glue it back and now it's been about 3 months and still works. If you want to get a used one then check ebay. Normally there are a couple of them for sale. You can also get one of the rebuild kit and try it, of course I did not do it that way but if mine came apart again I will try it.
I had put a 8" JL subwoofer in before but it did not sound as good as the ML so that's why I did the glueing.
Old Jul 24, 2007 | 10:04 AM
ancdmd's Avatar
ancdmd
get caulk and seal the cone, works great
Old Jul 24, 2007 | 11:52 AM
KINGLS430's Avatar
KINGLS430
SO the ML sub is better the the JL Sub?
Old Aug 2, 2007 | 07:57 AM
nmra200mph's Avatar
nmra200mph
just take it to the dealer if it is still under warranty. They replaced mine I had the same issue.
Old Aug 2, 2007 | 12:22 PM
jpcdmd's Avatar
jpcdmd
fixed mine with a bead of DAP Bathroom and Kitchen Adhesive sealer, just a bead around the outer edge of the cone, it takes about 30 seconds and you're done.
Old Aug 3, 2007 | 06:26 PM
bluegsx's Avatar
bluegsx
I used some black silicone (so it would be flexible)...sub sounds fine again with no problems. While I was back there (back seat out, back deck off), I ran the wire powering the stock sub through the trunk with connectors in the trunk. Now, I have a sub in a box in the trunk (sounds great) and if I ever need the room in the trunk, 10 secs to swap the connector and the stock sub is active again
Old Aug 3, 2007 | 06:27 PM
bluegsx's Avatar
bluegsx
what model JL 10" fits right in? W1?
Old Aug 4, 2007 | 08:44 AM
KINGLS430's Avatar
KINGLS430
Could u run both subs at the same time?
