Replace Rear Deck Brake Light
Old Oct 15, 2006 | 06:50 AM
cdnguy's Avatar
cdnguy
Default Replace Rear Deck Brake Light
OK - what's the best way to repace the rear deck (rear window) brake light in a 2002? The bulb has tuned out - and I'm not sure whether I should go in from the top - or from the trunk. Anyone know?
Old Oct 16, 2006 | 03:44 PM
LEX012006's Avatar
LEX012006
go in from the top. the housing pulls out and the bulb can easily be changed. it will take you about 3 minutes.
Old Oct 17, 2006 | 11:55 AM
cdnguy's Avatar
cdnguy
Lex - thanks - sorry - I must be a little slow today - how can I get the cover off the light? - I've tried pressing the 3 sides you can get at - and nothing. What am I missing?
Old Oct 17, 2006 | 04:40 PM
LEX012006's Avatar
LEX012006
I just recently had my back glass tinted and watch the guy pull firmly on the assembly and it came right out. He then disconnected the connector and placed the assembly out of the way to tint the glass. Grab & pull towards you, it comes right out (he did not use any tools!!).
Old Oct 24, 2006 | 08:04 PM
cdnguy's Avatar
cdnguy
Well, I finally figured out how to remove the housing. You have to move it 1/2" to the left, then lift it straight out. Then you can remove the connector wire, and the bulb assembly to replace the bulb. Thanks for the help, Lex.
Stango
Lighting
May 16, 2025 12:31 PM
davidyal
RX - 1st Gen (1999-2003)
Dec 23, 2012 06:17 PM
Matthew
26
Apr 18, 2012 11:13 AM
saelee39
Oct 3, 2007 04:55 PM
rduncan265
May 8, 2007 10:30 PM
