steering wheel vibration
Old May 5, 2026 | 02:26 PM
pswarner's Avatar
pswarner
3rd Gear
Default steering wheel vibration
replace front tension rod(strut rod) or bushings
Old May 5, 2026 | 02:46 PM
04LS430518's Avatar
04LS430518
Diagnose the problem then replace what is causing the issue. Suspension related noises could be a lot of things you need to narrow it down.
Old May 6, 2026 | 01:29 AM
BigBoomer's Avatar
BigBoomer
Steering wheel vibration is either wheel balance (fronts) or front suspension linkage bushes/ball joints.
If it happens at a certain speed, then most likely wheel balance or tyre damage.
Old May 6, 2026 | 06:29 AM
biacs's Avatar
biacs
I have had tires/wheels cause weird things with mine. Mark Each wheel/tire somehow. Rotate (and verify PSI) on them and re-test. See if vibration changes. A tire can go bad!
Bucketlist
Oct 1, 2025 01:27 PM
moses0324
Apr 25, 2011 05:24 PM
sc400123
Dec 12, 2008 01:59 PM
ghd8989
Feb 6, 2007 09:15 PM
