Seat belt extenders
Old Mar 23, 2026 | 03:32 AM
BigBoomer's Avatar
BigBoomer
Default Seat belt extenders
Has anyone on here had any success with getting a seat belt extender to fit the LS430?
I have tried a couple of so-called "universal" ones and whilst I got one to fit on the end of the belt, it wouldn't latch into the buckle.
The other "universal" one wouldn't latch at either end.
Yes, I know I need to lose some (a LOT of) weight but that's not as easy as it sounds when you have lower back issues. <sigh>
I can currently still latch the belt, but it's a struggle and the belt is fully extended.
For now I have reclined the driver seat a bit more as with the seat already all the way back it's the only way to make it easier.
Old Mar 23, 2026 | 04:35 AM
Leadfoot6's Avatar
Leadfoot6
Hi Big Boomer.
I sympathize.
I use 2 x extenders with my current car, a 2004 Mitsubishi Magna, and have been doing so for about 8 years without any problems, other than steering wheel clearance(height only, no reach).
It was about the only generally available car on the Australian market that would fit me.
I started with one, then purchased a second, which is now a semi-suitable arrangement.
These were purchased off Ebay, so I would consider them "universal".
No roadworthiness objections to this setup have been expressed at the annual safety inspections.
As far as I know, an LS 460 is going to provide me with more flexibility(read: more space) in this respect.
I am still trying to find the right car in the limited Australian market, hopefully needing to look for not much longer.
EDIT: Doing a new search has resulted in a lack of results of the type of extenders that I had purchased previously.
The only sort available now on Ebay are the "Airline" type of buckle.
I don't consider this type to be as useful.
https://www.ebay.com.au/sch/i.html?_...om=R40&_sop=15
EDIT ii: A general non Ebay search shows the type that I did originally purchase:
https://www.google.com/search?client...UTF-8&oe=UTF-8
Edit iii: I finally found the type I originally purchased on Ebay:
https://www.ebay.com.au/itm/33640783...iABEgIYOPD_BwE
They are useful not only for overweight drivers.
I purchased a second set to help with my mother's(R.I.P @ 100 years old 2/2025) arthritic hands.
It made it easier for her to buckle up without me needing to help.
Independence is very important for older people.
P.S. I have absolutely no back problems, surprisingly.
My issue(s) are both knees are shot.
Old Mar 24, 2026 | 03:38 AM
BigBoomer's Avatar
BigBoomer
Thanks Leadfoot, but that doesn't help with my problem.
The LS430 uses a seatbelt tongue shape that is quite different from the Mitsubishi one, so "universal" buckles don't work.
The cut-out in the tongue is a "shield" shape rather than a rectangle.
I was hoping someone out there could confirm that a particular extender worked for them, rather than me wasting more time and money.
Old Mar 24, 2026 | 05:15 AM
Leadfoot6's Avatar
Leadfoot6
Thank you for the information/image.
The 430 has a buckle/tongue type that I have not seen before.
uxrx
Aug 7, 2024 01:17 PM
svipani
RX - 4th Gen (2016-2022)
Jan 12, 2024 12:29 PM
TheLazyC
Dec 23, 2015 06:16 PM
DDLexus
Jul 21, 2010 11:10 AM
GlobeCLK
Sep 18, 2008 08:43 PM
