Need to run a wire to engine compartment
Old Jan 13, 2026 | 08:11 AM
SteveG129's Avatar
SteveG129
7th Gear
Default Need to run a wire to engine compartment
Base model, 2001 LS430 108k miles. I need to install a thin (<1 amp, 2 conductor) wire from inside the car, to the engine compartment. I will not drill any holes, or do any damage. I am willing to use spare wires that are part of the wiring harness, that may be spares for options I do not have. Suggestions please.
Old Jan 13, 2026 | 01:59 PM
JaySco's Avatar
JaySco
Under the battery tray there is a wiring harness that passes through the firewall. The rubber grommet that is used has a nipple on it, you can either poke a hole in the top of that nipple or just cut the tip off. It’s large enough to squeeze 4ga wire through so you should have no problem.
Old Jan 13, 2026 | 02:59 PM
alextv's Avatar
alextv
Agree use existing hole with grommet as that is what I always do.
Old Jan 13, 2026 | 06:50 PM
SteveG129's Avatar
SteveG129
7th Gear
Default A firewall grommet found !
This is exactly what I was hoping for! I never would have looked under the battery. Thanks !!
Lou77
Performance
Apr 4, 2024 12:18 AM
dadossenba
Jun 8, 2021 10:04 AM
orsmondjm
Mar 21, 2019 08:39 AM
JLRX350
Nov 20, 2012 05:24 PM
sonyman
Oct 17, 2005 05:17 PM
