Scanner and Check VSC Light
Old Dec 30, 2025 | 06:51 PM
Quinten's Avatar
Quinten
Default Scanner and Check VSC Light
If a scanner causes the check VSC light to come on is there any way other than jumping the OBD2 port pins to reset the light? Not sure which scanner I have (Innova, Foxwell or VXDIAG) may be the cause (maybe all of them since I used them all before restarting the car) but it would be helpful to know of any other way to reset the Check VSC. I do notice the sport and abs lights blink when using the scanners.
Old Dec 31, 2025 | 06:50 AM
alextv's Avatar
alextv
I use techstream. As I have said this car is very sensitive to what is connected to the port and sometimes does it but not always the VSC problem.
Old Dec 31, 2025 | 09:32 AM
Quinten's Avatar
Quinten
Thanks... I haven't been able to get techstream working yet with the VXDIAG VCX Nano with techstream 18.00.008. I have a mini VCI cable coming which comes with techstream version 17/18 so hopefully that works. What year LS430 and version of techstream do you use? I have a 2003 LS430 UL and a 2004 ES330 and neither one would communicate with the VCX Nano and Techstream v18.
Old Dec 31, 2025 | 10:05 AM
alextv's Avatar
alextv
2001 and 17.20.013. I have used 14 up to 17 with no problems but make sure you use corporate selection. Also works on my 2020 ES300h. Never tried 18.
Old Dec 31, 2025 | 04:18 PM
Quinten's Avatar
Quinten
What region/area did you select when prompted... North America or Japan? VXDIAG said I should use Japan but there wasn't a model option for LS430.
Old Jan 1, 2026 | 06:58 AM
alextv's Avatar
alextv
North America..Your new interface and software will probably work
bsprtsgrp
Nov 26, 2024 05:49 AM
AVSRacing
Dec 11, 2023 07:34 AM
Hope4lexus
May 16, 2022 06:13 PM
Xzon
Sep 1, 2021 03:03 PM
kevin11635
Maintenance
Oct 4, 2015 07:51 AM
