Fastener missing?
Old Dec 12, 2025 | 04:46 PM
Quinten's Avatar
Quinten
Default Fastener missing?
When changing the front brake hoses one of the plastic shield type pieces was flopping around. There is a small threaded stud that seems should have a nut on it to secure the shield. I check the other side and that was the same. I'll get a couple nuts and washers to keep it from flapping around but am curious what it should have to secure it?
Old Dec 12, 2025 | 05:26 PM
weldthedif's Avatar
weldthedif
should just be a regular old 10mm nut
Old Dec 12, 2025 | 10:27 PM
m6x1.0 thread.
Old Dec 13, 2025 | 07:24 AM
paulo57509's Avatar
paulo57509
Be sure to put a washer under the nut, or use a flange nut, so it doesn't distort the plastic. Doesn't need to be reefed on.
Old Dec 13, 2025 | 10:03 AM
Quinten's Avatar
Quinten
Of course home depot was out of the m6 flange nuts but O'Rielly's show they have some so waiting on the store pickup. Not sure of the purpose of such a small panel/shield and also why plastic push rivets like the other end weren't used. I wonder if the nuts just vibrated off over time or someone forgot or lost them.
Old Dec 13, 2025 | 12:12 PM
paulo57509's Avatar
paulo57509
You'd be surprised the half-a** crap that occurred before you took ownership. This wasn't the only thing that needed correction.
Air Cleaner Intake, RH - Lag Screw
Air Cleaner Intake, LH - Self-threading Bolt
The Fix - Rivet nuts....
....and Toyota bolts. The fit isn't great, but it looks better than it did.
Old Dec 13, 2025 | 02:36 PM
Quinten's Avatar
Quinten
Yes I'm finding a few things... wheel studs too short, wrong (and also needing replacement) battery (posts are towards the firewall), RF brake hose was twisted and kinked, brake pedal is on the low side. Replaced both front brake hoses and bled the brakes but need to do an ABS bleed... unfortunately neither of my scanners will do that with the Lexus, one worked with my Pontiac but the other didn't. Waiting on the VXDIAG scanner so I can run the techstream software. I'm sure I'll find more but it is a very clean car with a mint black interior!
e-man
Feb 13, 2023 01:58 PM
Curated Content Editor
May 30, 2018 08:57 AM
lexusk8
52
May 2, 2018 07:35 AM
JAB
RX - 1st Gen (1999-2003)
Mar 13, 2017 08:41 PM
pnyboy27
Nov 29, 2007 06:11 PM
