how to fix rough shifting with 6speed LS430?
Old Dec 5, 2025 | 11:44 AM
jjpls430's Avatar
jjpls430
Question how to fix rough shifting with 6speed LS430?
My 05 LS430's 6 speed transmission has been shifting pretty rough occasionally. When it happens its at low speeds it feels like youre in the car with someone driving a manual who isnt that great at shifting. Along with that whenever I put it in drive. about 1-2 seconds after it feels like thats when it actually shifts into 1st and the whole car feels like it wants to jump forward for a second. everyone feels it including passengers. I always come to a full stop before shifting and wait to let off the brake until it does the weird forward movement. Was wondering if anyone knows what either of these problems are/are from and how to fix either of them. Thank you for any help!
Old Dec 5, 2025 | 11:49 AM
LatinLS430's Avatar
LatinLS430
Sounds like your ECU needs some work. Common issue with the 04-06s.Here's a vendor that fixes it
https://taninautoelectronix.com/prod...ough-shifting/
Old Dec 5, 2025 | 01:10 PM
jjpls430's Avatar
jjpls430
I dont know much about this car, where could I find the VIN they describe to look for, both the 16 digit one and the ten digit one. (example of the 10 digit one : 89661-50692 )
Old Dec 5, 2025 | 01:14 PM
LatinLS430's Avatar
LatinLS430
The VIN should be in your door frame or the bottom left of your windshield.
The ECU is in the engine:
Repair service for the ECM of the 2001-2006 Lexus LS430
Old Dec 5, 2025 | 01:15 PM
jjpls430's Avatar
jjpls430
thank you very much this is a lot of help. deeply appreciated
Old Dec 5, 2025 | 01:38 PM
jjpls430's Avatar
jjpls430
Do you think its fine to unplug the ecu while the battery is connected or is it best to disconnect it?
Old Dec 5, 2025 | 01:41 PM
Quinten's Avatar
Quinten
Disconnecting the battery would always be the safest way.
Old Dec 5, 2025 | 01:44 PM
LatinLS430's Avatar
LatinLS430
Yes, always unplug the negative when dealing with electronics.
Old Dec 5, 2025 | 02:57 PM
alextv's Avatar
alextv
Vin for car bottom of windshield on dash driver side. Absolutely disconnect power for ecm removal.
Old Dec 10, 2025 | 08:54 PM
FanofLS's Avatar
FanofLS
Old Dec 11, 2025 | 07:32 AM
TominPT's Avatar
TominPT
One other tip - when you get it back from repair, be certain you hook all the connectors up to the proper receptacles - DO NOT MIX THEM UP. That happened to a LS400 owner a year or two ago and that simple mistake gave him no end of grief until he finally figured it out, car wouln't start, all kinds of issues. There is a thread on that in the LS400 forum, I could see this possibly happening with the LS430 ECU.
Old Dec 16, 2025 | 07:28 PM
V8_Fan's Avatar
V8_Fan
Sir it shifts down rough but not up rough, it’s the ECU. Had the issue on my 2005 LS. Sent ECU to a shop in TX, which repaired it. So far, 2 yrs later, no issues.
Basith
Jun 21, 2025 11:02 AM
Kuzen
Jun 14, 2025 11:01 PM
nkdsushi
Sep 20, 2022 08:27 PM
propcop
Aug 29, 2018 10:10 AM
BradTank
Sep 20, 2012 02:57 PM
