Power steering fluid
Old Dec 30, 2024 | 10:36 AM
jimisbell's Avatar
jimisbell
Default Power steering fluid
Does the LS 430...of for that mater, the SC 430 require special fluid for the power steering? I generally use any ATF for the job on my other cars.
Old Dec 30, 2024 | 11:41 AM
bradland's Avatar
bradland
Originally Posted by jimisbell;[url=tel:11839707
11839707[/url]]Does the LS 430...of for that mater, the SC 430 require special fluid for the power steering? I generally use any ATF for the job on my other cars.
Dexron III compatible ATF
Old Dec 30, 2024 | 11:42 AM
ExiledWolf84's Avatar
ExiledWolf84
Nope. Nothing special required here. Toyota's typically use the Dexron type of ATF for the power steering fluid so the good old Valvoline Maxlife works very well in these.
Old Dec 30, 2024 | 05:11 PM
jimisbell's Avatar
jimisbell
I got the Maxlife. Says Dextron IV so I guess that covers Dextron III
thanks
Old Dec 30, 2024 | 07:36 PM
intermec's Avatar
intermec
Still not sure about this topic as I always think power steering fluid is clear. Toyota ATF is red. I know most will say color does not matter. It still feel odd to me
Old Dec 30, 2024 | 08:09 PM
jimisbell's Avatar
jimisbell
I have never seen power steering fluid that was clear, but then I have used ATF in all my PS ever since the early 1960s when PS first appeared.....LOL
Old Dec 30, 2024 | 08:56 PM
Power steering fluid is often clear, but Lexus of this era does not use power steering fluid it uses Dexron II/III automatic transmission fluid.
Old Dec 31, 2024 | 02:10 PM
ExiledWolf84
For what it's worth, Honda Power Steering Fluid is clear, which isn't an ATF based derivative.
My old 75' Cadillac and my 12' Xterra both specify a specific P/S fluid From GM and Nissan, but they also stated that a Dexron ATF works just as well, so that's what I put into them
The old GM p/S fluid from the 1970s has probably been out of production for decades at this point anyway!
Old Dec 31, 2024 | 03:05 PM
paulo57509's Avatar
paulo57509
Dexron II or III was specified originally. Dexron VI is backward compatible with Dexron II/III. The "one-size-fits-all" ATF's that meet Dexron VI specs will work.
Keep in mind that Dexron II/III is not forward compatible with anything that specifies Dexron VI.
Old Dec 31, 2024 | 03:14 PM
Dex VI is claimed to be backwards compatible but in reality VI is a fair bit thinner for that reason I don't use it in power steering systems.
Old Dec 31, 2024 | 03:47 PM
Lexicon1's Avatar
Lexicon1
Been using Valvoline Synthetic ATF fluid in all my Toyotas for years....
Old Jan 4, 2025 | 06:02 PM
paulo57509's Avatar
paulo57509
Dex VI is more shear stable than Dex III. You might start out thicker with Dex III, but it'll eventually shear to Dex VI viscosity (or lower). I doubt it really matters in a PS application.
Old Jan 5, 2025 | 10:15 AM
jimisbell's Avatar
jimisbell
Is there a Dextron VI or is that a typo and you meant IV?. I did not see any reference to Dextron VI in the auto parts store.
Old Jan 5, 2025 | 10:56 AM
bradland's Avatar
bradland
Originally Posted by jimisbell;[url=tel:11842999
11842999[/url]]Is there a Dextron VI or is that a typo and you meant IV?. I did not see any reference to Dextron VI in the auto parts store.
https://en.m.wikipedia.org/wiki/DEXRON
Old Jan 5, 2025 | 11:17 AM
Stop telling people to use Dex VI in place of II/III it doesn't work properly. Don't care about any specs in real world use it's not suitable, I've tried.
