2006 LS430 fluid service
Old Nov 19, 2024 | 02:38 PM
yrusik's Avatar
yrusik
2nd gear
Default 2006 LS430 fluid service
My 2006 LS430 is coming up on 100k miles and it appears that the fluids (with the exception of engine oil) are original.
I would like to change ALL fluids this coming winter while I am not driving the car.
Please, what would be a reasonable shop cost to change ALL fluids?
Thanks,
B
Old Nov 19, 2024 | 08:19 PM
demark1's Avatar
demark1
each separate...
oil: $60 if non-synth, $100 if synth is typical around here. Dealer more.
washer fluid: Well, you did say "all". That one even I do myself, so $2.99!
power steering, differential, brake fluid, coolant: at dealer I'm thinking 150 to 200-ish each, from past experience. I've always done these at dealer. Similar to another car of mine, a Cadillac. good thing it's rare. brake every 3-4 years for me, diff around 60k or 10 years, did power steering just once. coolant every 5 years.
transmission: did it 10 years ago and they did fluid exchange machine. no drain and refill. This was priciest, around $300+ back then if I recall, for that high volume of fluid used. Probably more now.
Basically, nothing at dealer is under around $150 except a conventional oil change, or tire rotation maybe. And from what I have seen independent shops in NY metro area are not that much cheaper.
I( think I covered everything but gasoline and power door lock fluid).
Old Nov 20, 2024 | 06:36 AM
Romanova's Avatar
Romanova
Rear diff, $100.
Brake fluid, $175-200.
Transmission drain and fill, $200 (repeat 3x).
Coolant, $150-200 (do thermostat, hoses, OEM clamps at the same time).
Power steering fluid, $125.
Good luck!
hugo2648
Apr 26, 2023 07:35 PM
RG3toDC
Oct 28, 2018 03:07 PM
bryan11
Jul 24, 2018 12:27 PM
sf3r8z
Sep 1, 2014 08:29 PM
Threxx
Maintenance
Mar 5, 2006 09:59 PM
