Daizen Rack Bushings trouble...
Old Mar 14, 2024 | 12:06 PM
dumped430's Avatar
dumped430
10th Gear
Unhappy Daizen Rack Bushings trouble...
So I've recently taken some time to get around and install the daizen steering rack bushings but have been having some major issues since. My initial install was certainly wrong as an additional inch of the mounting spline was left hanging out of the nut/washer as I didn't consider the original length and was unable to find the torque spec at the time. Upon the steering getting real sketchy on a drive home I proceeded to revisit the bushings and tighten the spline until 25lbft but was still left with about a 1/2 inch of thread excessive to the nut. A week goes by - steering all of a sudden gets real sketchy again and I go back to tighten it but notice the nut is not quite as tight on the spline as before (still considerable, but not the recommended 87 ftlb) so I tightened the shaft some more it until where maybe 2-3 threads poke out when the nut is also tight. Once again, another week later and today I am feeling the looseness return and although I plan to return today and tighten the studs until no more threads peak, I am not 100% sure if this will correct my issue or if something else could be going on?
Any advice is appreciated, stud is highlighted green in the attached parts diagram photo
Old Mar 14, 2024 | 12:21 PM
pmesfun's Avatar
pmesfun
Did you install the bushing sleeves on the studs?
Old Mar 14, 2024 | 12:25 PM
dumped430's Avatar
dumped430
10th Gear
Bushing sleeves were installed while the stud was out and then screwed in afterwards, does this make any difference than installing it while stud is still in?
Old Mar 14, 2024 | 01:28 PM
bradland's Avatar
bradland
This diagram is not an LS430 steering rack. The stud part number is the same though.
Is there more to this or were you just using this diagram as an example..?
Old Mar 14, 2024 | 01:42 PM
dumped430's Avatar
dumped430
10th Gear
I was simply using that as an example as the bolt was already highlighted in the image and was the only rack I could find with an identical mounting style that showed everything. Here is the LS430 rack, though you can probably still understand most of what I am trying to imply from the other image
Old Mar 14, 2024 | 02:45 PM
pmesfun's Avatar
pmesfun
It shouldn't. If everything was installed correctly, I'm not sure why the nut is getting loose unless the threads are stripped. Can you post a picture of the bushings?
Old Mar 16, 2024 | 05:33 AM
ls430w140's Avatar
ls430w140
During or after the install was there a possibility that the steering rack adjustment bolt was touched?
DMPesso
Suspension and Brakes
36
Apr 2, 2022 12:26 PM
Thecar
Sep 24, 2019 04:14 PM
akafixture
Nov 10, 2014 08:05 AM
BigMikeAZ
Oct 17, 2013 01:12 PM
indypwr
Apr 17, 2005 04:02 PM
