Yup, you have cracks in the exhaust berween the Catalyser and the downstream O2 sensor.
This means that air gets into the exhaust which confuses the ECU and causes the codes.
Get your exhaust checked.
But could all this cause the engine to run lean? I mean i still hstilrhe feeling that i dont have full power and the gearbox shifts complete garbage...could this all be caused by the exhaust leak?
It could cause the engine power to be down and will cause the 2 codes, but the gearbox shifts are probably something else. Normally either the gearbox ECU needs repairing or new solenoids. It sounds to me like you have multiple problems. Fix the exhaust and then see what else needs doing.
Okay, i am going to a shop at Monday for a readout. After that iam going to repair the exhaust myself. Going to keep you guys updated.
Cheers
